Creative Geforce4 Ti4400 /w vented MV-WX
  • Sudum Gumudu
    • Sep 2005
    • 97
    Last night, the graphics card in my secondary box, a Creative Labs Geforce4 Ti4400 began to act up. Graphics glitches galore.
    Pulled it, and upon closer inspection discovered a bulging cap on it. There are five Sanyo MV-WX and four yellow (Fujitsu polymer ?) on it, and one of the Sanyos shows a distinct bulge.
    Sanyos aren't supposed to do that, right ? Hopfully it can be saved by a recap. Should I change all the Sanyos, or will changing the visbly bad suffice ?
    Pics to follow.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Creative Geforce4 Ti4400 /w vented MV-WX
    That was very intersting, yet troubling to hear
    Yes, a recap of only one cap should hopefully do it because I think it might have been one bad cap out of all produced... You would actually do us a favor if you only changed one cap and then reported back in a few months if the others has bulged/vented...
    Be sure to also post all stuff written on the cap if it can not clearly be seen in the pics...
    • Sudum Gumudu
      • Sep 2005
      • 97
      I'll do the bulged one first. If that fixes the problem, I'll leave the rest. And, here are the pics. It's hard to see on the pics, but they have the Sanyo logo, and series denominator WX marked on them. Four 470uF, 16v and one 1000uF, 6,3v.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Thank you for the pictures!
        I notice you use a heatpipe cooler, is it fanless? If so could you monitor the temperature of the card when looping 3dmark or something else that loads it 100%? (the general area around the VRM section where the caps are)
        Hoping you good luck with the recap, ps, I notice you are from Sweden, here is the part number in Elfa for the exact same type of cap...
        www.elfa.se Search for: 67-233-81
        • Sudum Gumudu
          • Sep 2005
          • 97
          Fanless it is. I'm beginning to think that was not such a great idea, the failed cap could be due to excessive heat. I will probably attach a ZM-OP1 fan to it if the recap is successful. I'll measure the temp without it first.
          The card is four years old, but has not seen heavy use the last two. The stock fan was used the first two years.
          Thanks for the Elfa tip. I had that all figured out though.
          • hkivan
            • Mar 2006
            • 122
            The die temp. of my winfast 6600 reach 75C at full loading with
            a copper HSF. IMHO, your fanless GPU should well above 75C on loading.
            In general , cap life span will double for ever drop in 10C according to
            a pdf from Rubycon. In this way, high temp. does kill caps whichever are
            good caps or not. Keep them cool will certainly extend their lifes.
            • Tom41
              • Oct 2005
              • 336
              • England
              It's odd for a 'good' cap to fail like that, but as said before it could just be one bad cap in a batch of 1000. The top didn't look bulged to me - it looked more like something had been spilled on the cap and wiped off, but couldn't be got out of the vent area. The side-on pic tells a different story though.
              It looks to me as if not only the top has domed up, but the bung at the bottom is coming out as well. Definitely worth a recap.
              You know there's something wrong when you open your PC and it has vented Rubycons...
              • Sudum Gumudu
                • Sep 2005
                • 97
                Changed the cap today, but the graphics glitches were still there. Then I found something out by chance. If I pressed against the inside of the VGA connector, the glitches became less pronounced. Tried the DVI connector with an adapter, and the card works fine.
                It would seem that the VGA connector is in fact the problem. Can anything be done about that ?
                • MD Willington
                  • Sep 2004
                  • 702
                  Replace the VGA connector and see if it helps, you still have the DVI to fall back on.
                  Ya'll think us folk from the country's real funny-like, dontcha?
                  The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    The problem could of course also still be in the monitors cable...
                    It's a PITA to replace those connectors, so much solder...
                    • Psionic
                      Creative Gigaworks ProGamer G500 troubleshooting
                      by Psionic
                      Hi
                      I have system Creative Gigaworks ProGamer G500 (production 2006 year). Last two months sound began to disappear, triger: use remote but wired volume controller. Sometimes sound system return back to correct mode but after changing volume problems return again. All LED indication concontroller corrects work - but sound absent.
                      Syndrome : if power off and connect headhones to wired controller - sound in phones play (looks like capicitors discharging) short time.
                      In google similar problems absent : present solution for unexpected cutting off or damaged amplifier chip....
                      07-02-2024, 04:19 PM
                    • Dukenukemx
                      Creative SB1350 identify component
                      by Dukenukemx
                      Front headphone connection stopped working on this soundcard of mine and I started checking for shorts and found some that go to this thing. I tried to Google it but nothing. Anyone know what this component is?
                      01-13-2024, 08:43 AM
                    • SkullKill
                      Creative GigaWorks T3 2.1-Channel Speakers
                      by SkullKill
                      The Creative GigaWorks T3 2.1-Channel Speakers keeps turning on and off in a loop.
                      open it up, and there was a swollen Decon SAII 2200uF 25V 85°C Capacitor in it. (the one on top right, next to the diodes)
                      replaced it with a 2200uF 50V 105°C Cap (just because this is what i had on hand, and there was space for it) , and it is back up and running. ...
                      03-05-2022, 06:01 AM
                    • notallbad
                      Indesit vented tumble dryer control board dead
                      by notallbad
                      Anyone able to help diagnose the fault with this board please.
                      Hopefully photos are clear enough to give me direction on what readings to take and where.
                      All ancillary components of the dryer have been tested and work i.e heating element, thermostats, sensors, motor, door switch, wiring harness.
                      So theres 230v at the control board but no life whatsoever with or without the ancillaries connected.
                      The on/off/timer dial contacts are clean and make good contact. All the through hole mounted components appear to be good i.e diodes, resistors,...
                      01-04-2023, 05:49 AM
                    • ChaosLegionnaire
                      creative audigy 2 zs shorted goldfingers
                      by ChaosLegionnaire
                      managed to get my hands on one of those as they are the best sound cards for win9x machines. however, when i received it, i noticed it had some scratches on the goldfingers. please view the attached pictures.
                      so i wanna ask, do the goldfingers look scratched and shorted together to u guys? is it safe to plug the card into the motherboard without releasing the magic smoke from the motherboard, sound card or both! ...
                      11-25-2022, 11:28 AM
