USB not working on Asus P4C800-E Deluxe
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Board has no physical damage I can find, except for a plastic corner broken off one Sata connector
    Has been updated to 2nd last BIOS (non-Beta) - I've found last Beta has pickiness problems with certain graphics cards
    Also tried downgrading BIOS
    Fresh install of WinXP shows usual USB stuff in Device Manager
    But testing with USB key lights up the key's LED, and that's it
    Asking WinXP to search for new hardware with the key plugged in, makes no difference
    Fuses near the USB ports show continuity, and I can't see any burnt traces
    Same outcome with a USB bracket plugged into one of the board's headers
    Have replaced all original LTEC 1000uf caps with Sanyo WG
    Various postings on the Net reckon i865 & i875 southbridges are prone to USB going faulty
    Seems to me that USB data lines are kaput - should I give up on it, or try something else ?
  • yyonline
    • Jul 2009
    • 692
    Re: USB not working on Asus P4C800-E Deluxe
    I've come across many i865 boards with dead USB ports. Have you tried all of the ports? Usually a few of them are dead, but it's rare that all of them are nonfunctional. I suppose it's possible, though.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      the i855gm in my old laptop blew out all 6 ports (2 on the unit, 4 on the dock). only fix was a new mainboard
      sigpic
      (Insert witty quote here)
      • Toasty
        • Jul 2007
        • 4171
        Latest chipset (Intel) drivers package installed? [ 7.2.1.1003 ]
        Overclock?
        Was a 1394 cable/connector ever used on those mobo connectors USB56, USB78?
        Done BIOS reset?
        BIOS default settings from menu?
        Enabled in BIOS? (Advanced header)
        Delete ports from within XP Device Manager, exit and shut down - COLD.
        Unplug mains to PSU and push power button on computer (lights flash, mobo light is extinguished)
        Reconnect power and restart system.
        XP discover ports?
        Does it find USB keyboard or mouse?
        veritas odium parit
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Here is the blurb on that:
          Since mid-2004, the large motherboard manufacturers noticed an increased complaint ratio with motherboards equipped with ICH5. A cause was the insufficient ESD tolerance of certain ICH5 steppings. [In other words the early versions.]
          In particular, when connecting USB devices via front panels, the chips died by discharges of static electricity. Intel reacted to the problem by shipping ICH5 with increased ESD tolerance. Effective ESD preventive measures on USB ports are difficult and costly, since they can impair signal quality of the USB-2.0 high-speed signals. Many motherboard manufacturers had omitted the necessary high-quality safety devices for front panel connectors for cost reasons.
          So to have the problem you need all three....
          1: Early version of southbridge.
          2: Motherboard manufacturer cheaped out on ESD parts. [Thanks Asus!]
          3: User was careless.
          Mann-Made Global Warming.
          - Dr Seuss
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            find a USB card, theyre really cheap now a days
            • pfrcom
              Oldbie
              • Jun 2006
              • 1230
              I've tried Intel's 6.3.0.1007 package which I thought was latest for i875
              Not overclocked
              Don't know history of board - anything's possible from the past
              Reset BIOS then load default settings every time I try a different BIOS version
              Is enabled in BIOS (doubt it'd show in Windows, otherwise) - also tried the 4 ports option, instead of 8
              Ports were discovered from a fresh install of XP - haven't tried deleting them, to see if they're re-discovered
              PSU has its own On/Off switch, so definitely mobo light extinguished for various tries
              Haven't tried USB keyboard or mouse - guess I should
              • pfrcom
                Oldbie
                • Jun 2006
                • 1230
                I have tried all four of the board's own ports, plus a bracket connected to at least one of the board's USB headers
                It's a Rev. 2.00, so late model southbridge combined with late model board cost shaving
                I have a NEC chipset USB card, but prefer not use it if I can get onboard ports to work
                • Toasty
                  • Jul 2007
                  • 4171
                  Which revision board is this..?
                  veritas odium parit
                  • pfrcom
                    Oldbie
                    • Jun 2006
                    • 1230
                    Rev. 2.00
                    BTW, the Sata connector with broken plastic does detect a disk, so I think unlikely to be the culprit
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      USB keyboard and mouse do not work with it either
                      • Gordon01
                        • Aug 2011
                        • 33
                        • Russia
                        What resistance datalines have to ground?
                        And once more: very common problem with ICH5, you can't fix that. Thanks god, that mainboard at least starts
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Have you tried any devices that do not use USB for power?
                          - Dr Seuss
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            That's only if ICH5 is the actual problem.
                            If you just see an ICH5 there and assume that's the problem you may be missing an easy fix.
                            Also as it's know the problem is lack of ESD tolerance for ICH5 you could add ESD filters before you break the southbridge.
                            - Dr Seuss
                            • pfrcom
                              Oldbie
                              • Jun 2006
                              • 1230
                              No - I don't have any devices that don't use USB for power
                              Need working USB for USB storage keys, and was hoping for a (possibly) easy fix
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                In that case the problem may be on the power side of the USB.
                                - Dr Seuss
                                • Gordon01
                                  • Aug 2011
                                  • 33
                                  • Russia
                                  You don't have a Printer, USB - SATA bridge or just active USB hub? Strange
                                  Easy fix is a $10 PCI card.
                                  • shadow
                                    • Feb 2007
                                    • 732
                                    He did mention that he has a NEC chipset PCI card (for USB). However he would prefer not to use it...and I can relate to this.
                                    • pfrcom
                                      Oldbie
                                      • Jun 2006
                                      • 1230
                                      Where would I start for diagnosis ? - had a desultory play with DMM testing MOSFETs in the USB area, without identifying anything wrong
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        See if you have +5v and ground at the ports.
                                        If you don't the device isn't getting power.
                                        What I've done when I wanted front USB and had to use a card is to take a USB cable and clip one end to connect to the front ports then run the other end out the back and plug it into the USB card port.
                                        Mostly did that for old P3 boards to get USB2 out front. [Instead of USB1.]
                                        - Dr Seuss
                                          ASUS ZenBook UX490UA-77DHDAB1 Notebook 3 Deluxe Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX490UA-77DHDAB1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX490UA-77DHDAB1 boardview and UX490UA-77DHDAB1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 09:37 AM
                                          ASUS ZenBook UX490UA Notebook 3 Deluxe Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX490UA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX490UA boardview and UX490UA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS ZenBook...
                                          09-06-2024, 08:29 AM
                                          ASUS ZenBook UX490UA-IH74-BL Notebook 3 Deluxe Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX490UA-IH74-BL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX490UA-IH74-BL boardview and UX490UA-IH74-BL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 06:48 AM
                                          09-06-2024, 06:30 AM
