Circuit board glue
  • yyonline
    • Jul 2009
    • 692
    Circuit board glue
    I am working on repairing an Acer AL2223W monitor. I opened it up to find bloated Capxon capacitors on the power supply board, and bloated Teapo on the logic board. So, the first order of business was to replace all the capacitors. However, the lamps still turn off after a few seconds.
    It seems like the inverter transformer is at fault here, as it has power to the transformer, but no power after it - so I ordered a new one:
    http://www.lcdparts.net/TransformerD...ber=T-8TC00332
    Now, the board has a blob of white glue over every one of the solder joints on the high voltage side. I'm assuming that this is for extra insulation. Does anybody know what this stuff is? I'm assuming that it's something digikey or mouser would carry, if I knew what kind of glue it was. It's the same flexible white glue that manufacturers love to smear all over power supply boards. It's not the hard glue that turns brown over time. It would probably work fine without it, but I'd prefer to have the extra insulation if possible.
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: Circuit board glue
    just use silicone,or decorators caulking,works fine i use it all the time,just make sure it has dried properly before applying power to the monitor
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Some of those products can be conductive when cured.
      If it doesn't mention non-conductive on the label or the manufacturers site then don't use it.
      Mann-Made Global Warming.
      - Dr Seuss
      • Krankshaft
        • Jan 2007
        • 2328
        Use Permatex Ultra Gray RTV from an auto parts store a Panasonic TV I worked on used a similar rubbery gray substance on the main IC contacts presumably for insulation purposes.
        The service manual didn't specify what it was so I used RTV never had any pin shorts or damage.
        • yyonline
          • Jul 2009
          • 692
          The existing stuff does appear to be very similar in texture to RTV silicone.
          Here's two options I came up with:
          http://www.mgchemicals.com/products/162.html
          It doesn't specifically say non-conductive, but it gives an electrical volume resistance that is (seemingly) very high. However, I am not familiar with the this measurement for this application. I'd welcome any thoughts people may have.
          • PlainBill
            • Feb 2009
            • 7034
            Either of those will work. I was also going to suggest GE Silicon II clear tub and tile sealant, but have not been able to find an equivalent datasheet.
            PlainBill
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • repair-it
              Engineering help - how does the charging circuit on this board work?
              by repair-it
              This board attaches to 2 12v batteries in tandum (Black/Red squares). There is a 24v power supply that attaches at the 2 pin molex connector (circled in red). I need help to determine which components run the charging circuit in an effort to determine a point of failure. There are multiple via's, making it difficult to trace the circuit. Nothing appears to be shorted but I wasn't able to fully test as I do not have 2 12v batteries available. My assumption is that the micro controller (red question mark) determines when to turn the charging circuit on & off. I'm pretty sure a regulator and...
              08-31-2024, 12:32 PM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
