My first recap -FAIL! Please offer advice.
  • Davisdog
    • Feb 2011
    • 10
    Howdy all,
    I've been lurking on this board for about two weeks now. I've read a ton of posts here and elswhere on the web.
    My mobo, a ECS HP MCP61PM-HM, out of a Compaq desktop had several bad caps, the identical situation as https://www.badcaps.net/forum/showthread.php?t=12149. I've read that thread several times and used the info there as the basis for my recap.
    I got my new caps in a couple days ago (from Badcaps) and have since installed them. Taking a lead from c hegge, I went with polys next to the processor.
    Prior to this project, I've been getting a lot of BSOD's. Sometimes the system would randomly reboot itself, sometimes just the BSOD and I would have to manually reboot. This started happening more and more often, until a couple weeks ago when during a startup, it got to the POST screen and the video went kind of crazy, with lots of goofy stuff all over the screen, then it locked up. After that, it fired up and sounded ok, but no video.
    I took it in to the Geek Squad. They weren't able to get it to work (no charge for the diagnostic). They even tried a brand new video card (I was hoping that was the problem) but no-go. Those guys pointed out the bulged caps to me. That is what got me to this website.
    Before I replaced the caps, the fans would spin whenever the power was on and the computer made all the normal beeps and such, just no video. After the cap job, it powers on for about 1/2 second, with all of the fans spinning, then it cuts off. No beeps, no video.
    I haven't got a clue what I did wrong. I did have some trouble getting some of the old caps off and I admit I may have jacked up this board. After it didn't work when I put it back together the first time, I pulled it out and re-heated all of the new solder joints. Still no-go.
    If anyone has any advice as to what I should try next, please help. If I can't get this going in the next day or two, I'm thinking I should just replace the mobo with a new one. If I go that route, I'll be looking for some help in that direction as well.
    I appreciate your help!
    Davisdog.
  • yyonline
    • Jul 2009
    • 692
    Re: My first recap -FAIL! Please offer advice.
    The symptoms you describe - powering on briefly and then power cutting out - can be caused by a short. When the power supply detects a short, it cuts power to the system. I'd pull the board out and very carefully look for any stray bits of solder that may have shorted something out. Hot solder can "jump" impressive distances while you're working, so be sure to look everywhere on the board.
    • seanc
      • Nov 2008
      • 1319
      Can you post pictures of your work so we can check for any accidental polarity swaps etc.
      • c_hegge
        • Sep 2009
        • 5219
        Try unplugging the 4 pin CPU Power connector. If it stays running like that, then the problem has to be around there. As seanc said, a shot of the board would be helpful.
        On a side note, I've re-capped four of these exact boards so far and in each case, I've used polys around the CPU and it's worked every time. In one case, I even replaced the 3 1800uF 16v lytics with 470uF polys and it worked. Therefore, the poly mod itself wouldn't be the problem.
        • Davisdog
          • Feb 2011
          • 10
          Thanks for the replies. I have just finished looking over the mobo for obvious shorts. I couldn't find any, but there are two very small suspect areas that I'm gonna give some attention to tomorrow evening. After that, I'll try running it without the 4 pin connector as c hegge suggested.
          One thing I'm concerned about: I don't have any alcohol or flux cleaner, so my solders look pretty nasty right now. Will the burnt flux cause any problems? Also, will stray solder that is not touching any terminals cause any problems (like just in a random spot on the green pcb, but not touching any exposed metal?) I don't see any of that, I'm just curious.
          I will try for some photos tomorrow night if the above does not work.
          Davisdog.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            any caps in backwards?
            • Davisdog
              • Feb 2011
              • 10
              No caps in backwards. I made a chart before I began and checked it several times both during the surgery and in post-op. I verified before I began that the half-moons indicate the negative side on all of the caps on this board. I actually printed out one of c hegge's photos of his board and marked it up as my road map.
              • bigbeark
                • Jan 2010
                • 661
                If you had to pull hard to get the cap legs out of the holes, you may have dislodged an internal trace or "via".
                Before removing caps you should apply fresh new solder The remelt the joint and work the capacitor back-and-forth until one leg comes out, then reheat the other leg and do the same until it comes out. For best results you need a good-sized chisel tip, at least 1/8 inch and an iron of 50 watts or better.
                Newer boards are much harder to work on because of the no-lead solder.
                The cap legs should slide out of their holes easily, with no feeling of pressing hard on the cap.
                • kiddznet
                  • Jul 2010
                  • 176
                  I'm with bigbeark
                  This bad boy 80W iron has them caps jumping off the board in fright
                  Easy to put them back on with it as well gives a nice neat pro looking job.Clip the cap legs before fitting
                  http://www.jaycar.com.au/productView...n&form=KEYWORD
                  939 DualCore AMD Opteron, 1800 MHz (9 x 200)
                  Abit AN8 / Fatal1ty AN8 SLI Series
                  3072 MB (PC3200 DDR SDRAM)
                  ATI Radeon HD 4300/4500 Series (1024 MB
                  Lian LI Aluminium mesh case
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5084
                    • New Zealand
                    I thought an iron like that could damage the board too easily?
                    -David VanHorn
                    • kaboom
                      "Oh, Grouchy!"
                      • Jan 2011
                      • 2507
                      I almost thought I trashed this one board. Intel OEM for Dell.
                      Got all the nasty old caps out in the VRM and ohmed out Vcore and 12Vin to the ground plane. Dead short on 12Vin. Here it was- this little solder splash from the hole of one of the 12v caps right to the ground plane. Looked close and found it. Pulled it off with solder wick and no more short. I thought one of the layers was shorting to a via...
                      Replaced ALL caps and perfection! When I got it, no boot, no nothin. I wasn't stupid enough to 'just try it,' as I saw the craps, both on the board and in the PS. People were blaming software as usual. And just how does software cause no power?
                      That thing booted right up like nothing was ever wrong. It did get the ol' format n reinstall, since some people 'mistreat' their computers.
                      All you have now is basic electronics troubleshooting- looking for that short. It's not any different because you're inside a computer. You'll find it.
                      -Paul
                      "pokemon go... to hell!"
                      EOL it...
                      All style and no substance.
                      guilty,guilty,guilty,guilty!
                      guilty of being cheap-made!
                      • Davisdog
                        • Feb 2011
                        • 10
                        Ok, I looked everywhere for a short. I couldn't find one, but there is a nasty area around where I struggled to get out one of the old poly's (I left the other two old poly's after that experience.) Some of the green is scrapped off in that area, but upon close inspection, there does seem to be space between the solder and the scrapped off area, so I'm not sure that's the problem. I am concerned about the internal damage I might have done there.
                        Attached are some photo's before and after the surgery. I hope they show enough detail, as they are the best I can do right now. I'm having camera issues that rival my computer issues at the moment. The first three photos are pre-op, the rest are post-op (maybe post-mortem.)
                        I did try the power cable suggestion - no difference. I tried it with one and two fans, with and without: memory, HD, processor, and just about every combination of all of that, it keeps doing the same thing.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5084
                          • New Zealand
                          Have you actually tested for shorts with a multimeter or just looked for them with your eyes?
                          There could be stuff going on between the underside of the capacitor and the board, where you can't see it..
                          -David VanHorn
                          • bigbeark
                            • Jan 2010
                            • 661
                            Ok, I looked everywhere for a short. I couldn't find one, but there is a nasty area around where I struggled to get out one of the old poly's (I left the other two old poly's after that experience.) Some of the green is scrapped off in that area, but upon close inspection, there does seem to be space between the solder and the scrapped off area, so I'm not sure that's the problem. I am concerned about the internal damage I might have done there..
                            When you say struggled to get out, what actually happened. Did you really yank on it?
                            Did you try to remove the other 2 polys? What size iron are you using? It's possible you could have broken the connection inside one of the other polys if you tried to remove them.
                            Whichever cap refused to slide out easily is probably the one causing the problem. Try reflowing that one.
                            Please test the board out of the case, see if that makes a difference. You've got a lot of excess leg-length on some of those caps, could be shorting to the case.
                            • Davisdog
                              • Feb 2011
                              • 10
                              bigbeark,
                              I did test it outside of the case, sitting on cardboard. Same deal. I'm using a 30 watt pencil style iron, from Radio Shack. One of the legs of the problem cap had broken off inside the hole. I had a heck of a time getting it out. When I was done, the hole looked pretty nasty. I have already tried reflowing it, along with all the rest, but there was no change. I didn't mess with the other poly's at all.
                              I don't have a multi-meter, so all I've done is a visual inspection. I would like to get a multi-meter, but my repair budget is getting pretty thin. My wife is getting to the point where she wants me to just go buy a whole new computer. I would like some recommendations on affordable meters though.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5084
                                • New Zealand
                                My multimeter was the cheapest one available from Dick-Smith. Normally $30 I got it for $20 on special.
                                So that's about $15-$20 US, I guess.
                                A cheap one will be better than nothing , but try to avoid anything _really_ cheap (say from a local Chinese shop for $2.50 or something)
                                Something cheap from RadioShack should be OK, but you might be able to get a good deal for a better meter 2nd hand on eBay or something. Garage sales where people don't know the value of things are always a good place if you get lucky
                                -David VanHorn
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  Two recent threads on the subject of affordable meters ...
                                  https://www.badcaps.net/forum/showth...ht=entry+level
                                  https://www.badcaps.net/forum/showth...end+multimeter
                                  Your best bet if you have patience and discipline is to buy one off ebay when it is mispriced. I have seen a few $150 multimeters from good brand names go for $20 to $25.
                                  Avoid anything that even looks like the generic 830B multimeter.
                                  --- begin sig file ---
                                  --- end sig file ---
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5084
                                    • New Zealand
                                    I just looked that up... and it looks just like what I have
                                    Mine has been going for years, sure it's cheap, and probably quite nasty, but its infinitely more useful than no meter at all. Also I can connect it to the mains and it doesn't explode, so it must be doing something right
                                    Then again, Dick Smith doesn't exactly sell total crap, so perhaps they got the version that actually goes through the QA department.
                                    -David VanHorn
                                    • kaboom
                                      "Oh, Grouchy!"
                                      • Jan 2011
                                      • 2507
                                      Reflow everything in the VRM and by the DIMM slots. Try to make the solder filets more cone shaped. It's real easy to have a short where the positive lead of a cap has too much solder on it, and that solder breaks through the solder mask and shorts to gnd plane.
                                      I've been known to use a soldering gun for stubbon areas. With heavy tips and 'trigger modulating', I'm good, but there's still less thermal mass than a large iron. I've never damaged or delaminated a board doing that. Normally, I use a 60w temp controlled Weller and a very old American Beauty. Get in, get hot, and get out.
                                      I would be doing someone a disservice if I told 'em to use a gun. I know just how far I can go with that. You don't want to practice on your first recap!
                                      Agent24, keep that 830 well away from 240V! Such behavior is right up there with little johnny sticking knives in outlets
                                      -Paul
                                      EOL it...
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5084
                                        • New Zealand
                                        Well it's several years old and it's been OK so far, used it many times on SMPS mains circuits and checking primary filter capacitors for charge etc, I don't see any reason to doubt its capability - im sure it would have gone up in smoke by now if it had any major issues.
                                        But I do not deny that it's a cheap meter, and would certainly recommend something better if one can afford it.
                                        (Say, something that can measure amps on AC for a start!)
                                        -David VanHorn
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
                                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                          09-12-2024, 02:00 PM
                                          GeForce RTX2080 Super Aero video gaming card issues help need
                                          by sam_sam_sam
                                          This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                                          Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                                          05-07-2023, 08:12 AM
                                        • Hondaman
                                          Windows 11 buying advice needed
                                          by Hondaman
                                          My mother may soon need to upgrade from Win7 (to continue safe browsing, e-mail, and office tasks, without a printer). Right now, she uses an Intel Core2Quad 9550 CPU (not sure of motherboard). Video is either the Radeon 6670 or 6770, completely air-cooled, with fins like a motorcycle engine (I think I pointed a 120mm fan at it). PSU is probably Seasonic, still running after 14 years (I choose quality). I am not sure of the RAM, or the PCI-e wifi chip. Probably 8 GB or 16 GB. Perfect for WIndows 7.
                                          She does not want to switch to Linux. And she does not want to use a laptop because...
                                          04-14-2025, 11:35 PM
                                          HP EliteBook x360 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                                          09-06-2024, 06:20 AM
