Recapping Sony ICF-SW55 - verifying cap values
  • proxneo
    • Jul 2022
    • 12
    • Netherlands
    Dear reader
    I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
    At the moment, I have selected replacements based on the following list of values:
    3 x 470uF 10VDC
    3 x 4.7uF 35VDC
    4 x 47uF 50VDC
    8 x 22uF 6.3 VDC
    1 x 220uF 6.3VDC
    5 x 100uF 6.3VDC
    Which is sourced from: https://sparedparts.com/products/68600276
    These values seem to be correct when looking at the amount present of each value and guessing their related dimensions (lowest capacity values and voltage are the smallest, as well as the highest being the largest).
    The printed text on the capacitor heads is as follows, in the same order:
    3x -printed on cap itself without code, no mystery there-
    3x 4.7 35v 18d
    4x j2 47 6v
    8x 22 6v 18a
    1x j4 220 4v
    5x 1y 100 6.3
    Some values correspond to the printed text, some do not or are counter-intuitive.
    A second source sort of verifies 4/6 of all different types, but doesn't show all. Furthermore, it is just text on an image, which could have been interpreted incorrectly by the primary author.
    https://www.radio-bastler.de/forum/s....php?tid=14433
    A third used source is a schematic of all components but that did not help that much as it also included other values, other than the ones in need of replacement, and isn't really clear on which is which (no Cxxx placement references on the PCB).
    Sony service isn't much help either in this case.
    Trying to identify based on printed values didn't work out for me.
    Yes, I'm aware recapping kits exist. However, not many ELC SMD are available, and I'm not planning recapping with tantalums. Furthermore, given the current state of capacitor legitemacy (via eBay), I'd rather source my own via reputable sources. Plus, this give me the opportunity to place some better ones (e.g., 50VDC instead of 35VDC) and have some spares.
    I have selected the following replacements, in the same order as listed above, with "low ESR" ratings where possible (TME because it's the only one with all in stock and delivers to individuals):
    https://www.tme.eu/nl/en/details/zsc...citors/vishay/
    https://www.tme.eu/nl/en/details/eee...ors/panasonic/
    In closing, I'd like to ask if anyone can verify the list of values as posted in the beginning of this thread.
    Thank you in advance.
    Kind regards,
    proxneo
  • proxneo
    • Jul 2022
    • 12
    • Netherlands
    Re: Recapping Sony ICF-SW55 - verifying cap values
    Back again. I have already ordered the parts and performing the repair. I have, however, stumbled upon a few exposed traces and one broken trace path (all a result of damage by leaking cap acid), so it's a bit more work than I had anticipated.
    Anyway, a few days ago I found a new source, one I hadn't found before, listing a more complete service manual than found on elektrotanya and radiomuseum etc.
    https://www.petervis.com/manuals/son.../icf-sw55.html
    Thanks to this upload I was able to verify the values.
    I have included a PDF file with the relevant schematic and component numbers, including values.
    This schematic also showed me a hidden cap, on the left bottom hidden behind a metal shield. The value of this cap is 47uF 6.3VDC, named j2 47 6v. That makes a total of 25 instead of 24 SMD elco caps fit for replacement.
    For anyone interested, the original values, according to that service manual, are as follows:
    • 22uF 6.3V
    • 4.7uF 35V
    • 100uF 6.3V
    • 470uF 10V
    • 220uF 4V
    • 47uF 6.3V
    For anyone interested, I have ordered the following parts:
    • ZSC00AG4711CARL
    • EEEFK1H4R7R
    • EEEFK1H470XP
    • EEEFK0J220AR
    • EEEFK0J221P
    • EEEFK0J101AP
    • charlidson
      • Mar 2025
      • 1
      • Sweden
      This is brilliant, just bought a SW55 that requires recapping and to find this information is invaluable. I also going to replace the Super Capacitor which is this part from the TME website KR-5R5H224-R. All I am looking for now is a replacement LED for the side lit display?
      Best
      Charlie
      • Carlos#2003%
        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
        by Carlos#2003%
        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
        02-15-2024, 07:52 PM
      • dkneyle
        Sony KDL-46HX850 Can't upgrade/update firmware
        by dkneyle
        Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
        Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
        09-25-2024, 10:44 PM
        Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
        This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
        09-06-2024, 05:27 AM
        Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
        This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
        09-06-2024, 05:30 AM
        Sony VAIO SV-T1122F4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
        This specification for the Sony VAIO SV-T1122F4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SV-T1122F4E boardview and SV-T1122F4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
