hp 15-cw0010na bios
  • layad
    • Nov 2011
    • 244
    hp 15-cw0010na bios
    hi there
    hp 15-cw0010na , SR: 5cd947477f
    G7BE DAG7BEMB8D0 Rev: D
    anyone can help mewith fixing the bios dump pls
  • peste
    • Dec 2016
    • 13199
    • ROMANIA
    Re: hp 15-cw0010na bios
    Originally posted by layad
    hi there
    bios extracted from the HP sit6e update, the laptop has three bios variants, yours is 084E5
    DMI 0 - 10FF
    KEYWIN 8000 - 803F
      • 21467
      If you can`t use a hex editor you can still add the DMI yourself using this guide https://www.badcaps.net/forum/showthread.php?t=116311 .
      Follow the Easy guide and use this attached script.
      • ay_bulut
        • Feb 2016
        • 114
        • turkey
        Follow the Easy guide and use the attached script.
        Hi, it's giving an error. Could you help
          • 21467
          Did you use the script from post #3 .Did you check your backup to make sure its good ? ,post it here
          Edit: I think you could have a double file extension,can you check your windows (explorer) Folder options, look for a setting called "Hide extensions for known file types" and untick it. oldbios.bin should only have .bin ,let me know if its something else after .bin
          • ay_bulut
            • Feb 2016
            • 114
            • turkey
            Thanks, problem fixed.
              • 21467
              what was the problem
              • ay_bulut
                • Feb 2016
                • 114
                • turkey
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • Wahaz
                  by Wahaz
                  10-30-2023, 08:42 PM
                • lucaszmn
                  Summary of BIOS Whitelist Removal Problem Lenovo Thinkpad T560
                  by lucaszmn
                  Problem:
                  I am attempting to remove the WWAN card whitelist from my Lenovo ThinkPad T560.
                  Initial Findings:
                  • My current BIOS version is N1KET58W (1.45).
                  • I have a CH341A programmer and have successfully created two full backups of my BIOS.
                  • I have the ability to use command-line tools on a Linux machine.
                  Troubleshooting Steps & Conclusions:
                  • I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
                  • I concluded that the
                  08-12-2025, 03:01 PM
