Samsung UN65NU6900FXZA Vertical Gray/Dim Area
  • 80r15
    • Dec 2022
    • 14
    • US
    My gut instinct is that the panel needs to be replaced, but looking for outside opinion on any other possible cause, hopefully without the excessive cost to fix/replace. I'm going to take the time over the weekend to take a look at T-con and check voltages, but again, given the pattern on the screen, odds are slim, if none, that is any potential contributor to the issue observed.
    Thoughts? Much obliged, and Happy Holidays!
  • lotas
    • Jan 2016
    • 4752
    • Russia
    Re: Samsung UN65NU6900FXZA Vertical Gray/Dim Area
    If you are talking about a dark spot on the screen, then it looks more like LEDs (fail), there is no separate T-con on this chassis, it is built into the motherboard.
    • Diah
      • Feb 2013
      • 6435
      its remark of the panel will be shorted soon.. don't waste money,, NU TU MU all rubbish panel.
      • lotas
        • Jan 2016
        • 4752
        • Russia
        Well, the MU series is still tolerable with a panel and backlight, but the NU, TU, RU series - yes, one marriage.
        • Diah
          • Feb 2013
          • 6435
          lotas at the end all with U end are Sami fucking cheat.
          • 80r15
            • Dec 2022
            • 14
            • US
            No, it's that entire gray area. It would be nice if it were the LED's, but not the case...
            • nicholas1110
              • Aug 2012
              • 127
              • usa
              This does look like failed leds. Specifically maybe only 1 or 2 leds out. You can see on the bottom one specific spot were it is slightly darker which is the led that is out. You can confirm by removing the screen and turning the leds on you will likely see a few not lit. It’s very common on this series of TVs. Leds are inexpensive for this model and worth replacing as long as the diffuser here has not melted or cracked.
              • Storyteller12
                • Jun 2020
                • 625
                I agree. I'm curious what tv you have and what brand/ models you recommend?
                • Diah
                  • Feb 2013
                  • 6435
                  Originally posted by Storyteller12
                  I agree. I’m curious what tv you have and what brand/ models you recommend?
                  now days all brand start with low coast production ( All In ALL ) no recommendation.. but before was all brands hold long.. as my Hisense from 2016 & LG 3D LA series from 2013, both until now never opened the back cover...
                  • 80r15
                    • Dec 2022
                    • 14
                    • US
                    Yeah, I now think that's the case. I put up the post to get some quick insight before I had a chance to completely dissect the design of the device. As it turns out, this only has the bottom/top *two* LED strips (finally took the time to look at the internal specs this evening), so that means the issue at hand is completely feasible. Had I known there were only two, my initial impression would have been much different, but it's been roughly eight years since I did a repair on one of our tv's, so of the cuff I was still thinking of the old school way.
                    You're right, LED's are cheap, so ordering some tomorrow, worth the risk since odds are in favor (drastically).
                    Thanks again!
                    • nomoresonys
                      • 12276
                      • U.S.
                      • Ihandyrepair
                        • Sep 2017
                        • 44
                        Samsung uses bottom edge for the led back lights, specially the NU mu models. The worst parts, if led failed or burnt, diffuser might be melted or cracked.
                        I just finished replacing on 50NU Samsung burnt one side led backlight. Melted diffuser. Had to cut the melted area and turn the white back paper 180 as there some brown burnt area.
                        At first I cut only the melted area. Put everything back, not good. Tv would have white spots areas at the bottom where the light passes through the cut area. Forgot to take pic.
                        Tried again by cutting the entire lane bottom and works, image looks even. No brown spot.
                        Not much I could do with the crack, slight white spot area
                        • Diah
                          • Feb 2013
                          • 6435
                          interesting ,, how did you succeed cutting the hard defuser plate with out break it !!?
                          • Ihandyrepair
                            • Sep 2017
                            • 44
                            rotary tools, make sure is sharp and cut small amount at the time. Need to find the right speed and force.
                            Too fast too much, you can melted the diffuser instead of cutting.
                            Here are the only downside
                            After cutting the bottom, removing the melted brown area, the diffuser is a little shorter at top.
                            There is a small gap, so you can see a little whiter on top, light leaks out
                            So next time, I know, I will put white tape so light can't leak out.
                            Didn't want to remove the panel again, already did so many times,
                            Worry I might break it.
                            Pictures with colors is not that bad
                            You can still see a little of the crack when the image is white.
                            But this is so much better image at the bottom.
                            Before I remove the bottom section, the right side would show bunch of white spots.
                            • alfatv
                              • Sep 2020
                              • 353
                              Not all NU's are that bad, sometimes backlight replacement is enough.
                              There is separate thread about NU meltdown, better post your findings over there:
                              https://www.badcaps.net/forum/showthread.php?t=96567
                              • 80r15
                                • Dec 2022
                                • 14
                                • US
                                Thanks guys, it was indeed the LED strip, finally had time to do the replacement last night and the picture is back to normal. After looking at photos, Samsung service said that they wanted to replace the panel, for *only* $1055...
                                • 80r15
                                  • Dec 2022
                                  • 14
                                  • US
                                  OMG... and less than 24 hours since swapping the new LED strips and the new strips have failed.
                                  • lotas
                                    • Jan 2016
                                    • 4752
                                    • Russia
                                    Well, apparently they installed not high-quality ones, a Chinese fake.
                                    When installing a new backlight, it is necessary to glue it on hot glue or thermal adhesive tape (heat-conducting heat-resistant double-sided tape) and limit, reduce the backlight current in the power supply.
                                    https://www.youtube.com/watch?v=YEbxGmBBYjE
                                    • 80r15
                                      • Dec 2022
                                      • 14
                                      • US
                                      I used these from ShopJimmy. The strips are installed with double-sided tape, can't verify that it is indeed thermal, but it came preinstalled on the strips. What is the reason for needing to reduce backlight current in the power supply?
                                      What is odd is that we turned the tv off when we went to dinner last night, and when we returned we turned the tv back on and the section of LED's that were no longer working *were* working, but only for roughly ten minutes and the rest are uneven in output. Thoughts other than bad strips?
                                      • nomoresonys
                                        • 12276
                                        • U.S.
                                        well your Right Diah, NONE of them are any good.
                                          Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
                                          This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                          09-07-2024, 12:10 AM
                                          09-07-2024, 05:50 AM
                                        • Falki
                                          Colorful LCD Vertical Lines on Samsung ue55es8090
                                          by Falki
                                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                                          Sadly it has vertical lines at the left and one line in the middle-right.
                                          I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                                          I have factory resetted the TV as well but also with no luck.
                                          I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                                          A similar issue has been posted as well but also with no actual response ...
                                          08-12-2025, 04:19 AM
                                        • kotel studios
                                          Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                                          by kotel studios
                                          Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                                          In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                                          08-06-2025, 02:07 AM
                                          09-06-2024, 11:40 PM
