PS5 power supply not working
  • zwerw3
    • Jan 2021
    • 12
    • Казахстан
    Hello. Brought Sony PS5 with a malfunction does not turn on. Found that the power supply is not working. No visual defects were found. Full fuse. Capacitors C2, C5 are charged (voltage comes to them). Does anyone have a diagram or can you please tell me how to fix it. Little experience with power supplies. I will be glad for any of your help. Thank you.
  • zwerw3
    • Jan 2021
    • 12
    • Казахстан
    Re: PS5 power supply not working
    DAP 0537 gets very hot. I wanted to order from Aliexpress, but there is no such thing. Are there any analogues of this chip? Thanks.
    • R_J
      • Jun 2012
      • 9559
      Re check the number I think it is a DAP 053T , This is the APFC/PWM controller ic
      I also found this which might help
      Also the DAP053T seems to be a TEA2016AAT/1J
      • zwerw3
        • Jan 2021
        • 12
        • Казахстан
        Thank you very much. I will check, I will give you an answer later.
        • zwerw3
          • Jan 2021
          • 12
          • Казахстан
          These are the readings on my power supply
          • zwerw3
            • Jan 2021
            • 12
            • Казахстан
            It is unclear how to check EL 1013? Like a regular diode between 1 and 2 pins, and 3 between 4 pins? Tell me please.
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              Maybe this will help you as pinout ..
              • jiroy
                • Jun 2016
                • 2416
                • Lebanon
                Is this your EL 1013 ?
                • zwerw3
                  • Jan 2021
                  • 12
                  • Казахстан
                  ll46 1004 w
