Nintendo 3ds xl. dead after home button replacement
  • gergely
    • Oct 2017
    • 25
    • Spain
    Hi!
    I have this nintendo which had a bad home button. I've ordered a new one and when i mounted everything it didnt turn on.
    I did some measuremnts which you can see in the pictures.
    Could someone help me if i shorted something?
    Thanks.
    the zip file has 2 pictures with diode readings
  • lotas
    • Jan 2016
    • 4804
    • Russia
    Re: Nintendo 3ds xl. dead after home button replacement
    You are missing some kind of dc converter.
    • double_DD
      Transformer replacement for a dead coffee machine
      by double_DD
      Hi guys,
      I have a dead coffee machine, and it seems that the culprit (no 1, at least) is a dead trafo - primary coil seems to be blown open (type shown on the picture below).
      Now, I'm unable to find direct replacement anywhere on ebay or aliexpress, and all similar that I' was able to find are rated too low (<1A).
      If someone knows a shop to buy replacement (EU/CH), that would of course be my 1st option.
      My other ideas:
      - to buy 220/20Vac trafo with 30VA, and to "manually" create secondary 12V output just via resistor
      - to buy...
      06-23-2025, 05:43 AM
    • themosttogain
      HP Envy 13-BA1565na with intermittent power button
      by themosttogain
      Hope someone can give me some suggestions on this because i'm at my wits end with it...
      I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
      Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
      07-12-2024, 03:03 AM
    • Andreasbest
      Dell Latitude 7410 dead and amber light as long power button is pressed.
      by Andreasbest
      Hello.
      I received a bios locked 7410 with 25Q256JVEQ ,i dump the bios, unlocked it and flash it back, since then the laptop has no life signs at all except amber led on for as long the power button is pressed, nothing else.
      Fact #1 i was unaware that 25Q256JVEQ is 3.3v and i used a 5v CH341A to program it, not sure if the chip got damaged but since then i can read it and write it normally, doesn't seem dead.
      Fact #2 i modded the CH341A to 3.3v, same results with programming though, nothing changed.
      Fact #3 i tried hard reset with cmos/main battery disconnected and power...
      12-21-2024, 02:02 PM
    • CraigR
      Nintendo switch dead.
      by CraigR
      I got in 2 Nintendo switches that appear dead but the amp meter shows charging. I removed the board and just the plain board plugged in with no battery and it draws 0.10A so I checked for shorts and did not really find anything but under the thermocam I see the MAX77620A chip lights up on both of these. I never had to replace that chip before. Is this common and just my luck I get 2 in a row? Or is this normal and I should look elsewhere? I have also replace the M92 and BQ with same results.
      12-19-2024, 06:01 PM
    • estabilito
      Nintendo Switch Oled dead
      by estabilito
      Hello, i bought dead nintendo switch oled.
      after plugging charger with amp meter device shows 5v and 0,0 or 0,02 amperage draw.
      I inspected motherboard and someone tried to reflow or replace m92t36 and didn't do it well, i resoldered it proper and find that usb-c fuse was blown too(replaced it).
      After this device started to draw 15v and something around 0,48 but only for few seconds after this returned to 0A draw.
      I tried to plug motherboard without battery - shows 15 0A and when charger was pluged i put battery back in then console started to charging battery but stuck...
      05-07-2024, 03:48 PM
