LG PDP42X32000 panel
  • fastvideo
    • Dec 2008
    • 55
    I pick up a 42" RCA plasma tv. It has no image on screen sound ok.
    Found fuse blown and shorted ic on y board. Replace with STK795-820 and fuse, unit has image and sound now.
    If I adjust the voltage according to the panel's spec, I got a red snow screen. Have to lower -VY and Vzb to minimize it, but I found the screen still has some kind of red, blue statics when image change from a bright scene to dark. Or when no video signal input.
    Tested with another CTRL board, same problem, so is this a sign of aging panel or I should test it with other y and z module?????
  • PlainBill
    • Feb 2009
    • 7034
    Re: LG PDP42X32000 panel
    I vaguely remember wizard indicating this might be the sign of a dying panel. If you haven't done so, I'd suggest downloading LG's Quick Alignment Guide and doing the full adjustment of the power supply and the sustain cards.
    PlainBill
    • cadiman
      • Mar 2010
      • 397
      I had the same 42x32 panel. It had the same issues you are talking about. It really wasn`t that bad if you stand back about 5 feet. I set all voltages by the book and had set a good waveform on the y board. I then tried adjusting va and vs on the power supply. Changing v on the Z board didn`t help either. I seemed to be from the Y board.
      I have read here where other people have had the same problem with this panel. I replaced the ic and caps( Y board). This panel was a 2006 I repaired it in 2009.
      Also my panel was used for a vizio. Not the best. It was l/g, but all the heat sinks were missing from the buffer chips. Could have been some corner cutting in other areas as well.
      • fastvideo
        • Dec 2008
        • 55
        I bought it defective as is.
        The STK795-820 I got from my supplier looks like old inventory.
        Don't know if having the red snow problem before it was down or the STK is causing the problem.
        • cadiman
          • Mar 2010
          • 397
          That was the same thing I ran into. I have worked on other L/G panels, but nothing made for vizio only L/G and insignia (L/G). They both had good pictures. I won`t buy any broken vizios they are just made too cheap.
          I may have missed something that needed replaced on the y board. Just cause I had a picture didn`t mean I repaired it. I figured I would see a problem in the waveform.
          • fastvideo
            • Dec 2008
            • 55
            "Adjust the voltage according to the panel's spec, I got a red snow screen. Have to lower -VY and Vzb to minimize it, but I found the screen still has some kind of red, blue statics when image change from a bright scene to dark. Or when no video signal input."
            Swapped the Y board, Z board and CTRL board, to another TV. Adjust the voltage according to the panel's spec. No red snow problem.
            Aging panel confirmed on this 42" RCA plasma tv!!!!!!
            • Raulnn
              Tdsystems K40dlt3f Panel V400HJ6-PE1 REV C2 short circuit no image
              by Raulnn
              good evening. I have put the panel model, because it is a generic Chinese tv. The symptoms are the following: The rear light turns on, but there is no image, 12v arrives at the tcon integrated in the panel. I have made measurements of vgl, vgh and vaa. They are not present but they all act as rectifiers except for vaa, which is shorted. my questions are. Do you know any quick method to know the capacitor that is shorted without having a laboratory source? How could I know the value of the capacitor once extracted? I can't find schematics for this panel. a greeting
              12-20-2022, 05:11 PM
              HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
              This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:20 PM
            • howardc64
              LG 49UJ6500 LCD panel lighter band that goes away
              by howardc64
              49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
              Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
              02-19-2023, 12:13 AM
            • Jaime Morillo
              Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
              by Jaime Morillo
              Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
              The TV was stuck on the logo and I couldn't access the update menu.
              I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
              The image result was good, but the image is inverted.
              The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
              Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
              08-18-2025, 11:38 AM
            • Storyteller12
              QN55Q60R Service Menu Panel Help
              by Storyteller12
              I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
              I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
              I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
              the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
              01-13-2024, 01:57 PM
