Sony Vaio SVF1521K4E BIOS dump & help request
  • sijones99
    • Jan 2022
    • 11
    • United Kingdom
    Hi All, firstly big thanks to the forum members SMDFlea, piernov & mon2 who have got me this far, from when I posted over on this thread:
    https://www.badcaps.net/forum/showthread.php?t=102806.
    Background:
    My brother's Sony Vaio SVF1521K4E appears to have a corrupt / missing ME Region firmware. When I boot it into BIOS I can see the firmware is listed as version R0250DA, but the ME Version says 'UnKnow'.
    The symptom is that the machine boots, but shuts down 30 minutes later. It currently has no Windows installed as its hard drive failed a while back. It now has a Linux install on a tatty old HDD that I had lying around.
    What I have done since my original post:
    • On the advice of SMDFlea I got a CH341A programmer, clip & accessories.
    • I've done the soldering mod to bring the voltage down to 3.3v.
    • I've successfully read the current (probably damaged?) firmware on the laptop's WINBOND 25Q64FVSIG chip. I was amazed and delighted that I managed to do this, as it seemed like sorcery to me...
    SMDFlea suggested that I post my firmware download in this sub-forum, in the hope that someone brighter than me could suggest what might need editing in there to fix the damaged ME data.
    I've attached two copies of the firmware I saved from the chip: as a .bin file, and a .hex file (I wasn't sure which was appropriate), together in a RAR archive.
    I'm a real novice at this stuff, but eager to get stuck in & learn. I now know how to flash it back onto the chip if someone could help me work out what's going wrong in the firmware.
    Thanks in advance for any help you can give!
  • peste
    • Dec 2016
    • 12786
    • ROMANIA
    Re: Sony Vaio SVF1521K4E BIOS dump & help request
    Background:
    try..
    • sijones99
      • Jan 2022
      • 11
      • United Kingdom
      Thanks for your fast reply peste - I tried to write that file with Neoprogrammer, but the operation completed in less than 1 second, with the message:
      Verification error on address: 0x0000101B, Device: 0xA0, Buffer: 0xEE
      I guess the operation should take a minute or more?
      Does that message suggest anything to you?
      [edit: I'm reasonably confident that the clip is seated OK - I can still use it to read from the chip...]
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        Тhere is no good contact between the clip and the chip, adjust the clip in a way that ensures good contact. Be careful with the orientation of the clamp relative to the chip (pin 8 is + 3.3V). Remove the battery. Check the continuity of all eight wires between the clamp and the programmer. The wires are very thin and are often desoldered (or are torn) from the clamp pins.
        Become a Badcaps supporter
        Thanks to all supporters.​
        • sijones99
          • Jan 2022
          • 11
          • United Kingdom
          Thanks Vesko 356 - I have now removed the CMOS battery - I never thought to do that.
          The wires have good continuity & I have pin 1 in the correct location. I have re-seated the clip many times, and I can read the current firmware from the chip OK, but I cannot write back to it, I get the same error:
          This may be a stupid question: right now I am trying to write peste's .bin file over the current file that is already on the chip. Or should I erase the chip first, then write?
          I am new to all of this, trying to learn the techniques!
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            You should first erase the contents of the chip, and then to program the new dump.
            • sijones99
              • Jan 2022
              • 11
              • United Kingdom
              How embarrassing... here in the UK we call that a "schoolboy error"!
              The YouTube video that I watched did not have that step, so I did not think to do it!
              peste's .bin file file has now flashed successfully! I will rebuild the laptop and see what happens. I will report back to this thread with the results.
              Thankyou peste & Vesko356 for your kind help & advice.
                • 20873
                If peste`s bios doesn`t work try this one .
                • sijones99
                  • Jan 2022
                  • 11
                  • United Kingdom
                  Hi everyone, thanks again for all your help & support, I had a great result last night: once I had flashed peste's .bin file I rebuilt the laptop, and ran it for a few hours (using Linux Mint on an old HDD). The computer stayed running - no 30 minute shutdown!
                  Next I put in an SSD and installed Windows - that went very smoothly (before the flash, the laptop could not recognise my SSD). After a few Windows Updates the laptop is still running beautifully - and it's very responsive. I have it powered on right now for an extended test, if it remains stable I'll install Office and return it to my brother.
                  Massive thanks to peste, Vesko356 & SMDFlea for helping a complete stranger with this problem - this computer has been saved from landfill.
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    Well done! Good job buddy, congrats!
                      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-06-2024, 05:27 AM
                      Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                      This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                      Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
                      This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      Sony VAIO SVT1122I4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                      This specification for the Sony VAIO SVT1122I4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVT1122I4E boardview and SVT1122I4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    • Carlos#2003%
                      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                      by Carlos#2003%
                      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                      02-15-2024, 07:52 PM
