Surface 4 Pro BIOS locked
    Surface 4 Pro UEFI Password - How to Remove?
    Hello there, i have a surface 4 pro with forgotten uefi Password. How can i remove it? I'm a noob at this point so please explain (also directly on PN possible) what to do. ive read some threads here and now tried to extract a dump of my bios with Intel fpt but with no success (Error 316). I also tried the hibernate trick with no success.
      Re: Surface 4 Pro UEFI Password - How to Remove?
      You have a bin file 16mb?if yes post here i try remove.
        surface pro 4 password
        need help to remove password orignal file is attached
          Re: surface pro 4 password
          waiting
            Originally posted by alihomee View Post
            waiting
            here is your dump with clean bios.but i am not sure if it wil keep the motherbord serial,uuid..
              thanks i will post results after try
                Originally posted by zaleon View Post
                Hi, thanks for your reply. I have tried without the -BIOS before and it complained it couldn't read that flash area or something to that affect.
                I believe after writing to another member here with the same issue, that iamromroni is correct and the only way to get the full dump is to open up the tablet and read it using a physical programmer.
                However, the Surface Pro 4 from what I've read is extremely difficult and time-consuming to get into without damaging it, so I'm not willing to go that far as long as my Windows is still working. I appreciate your assistance in trying to resolve this issue. This is a great forum!
                did you ever get anywhere with this?
                not only do you have to open the surface (which is a chore), but you have to remove the chip because it's WSON style and cannot be connected in situ.
                at any rate, I have a cleaned dump for surface pro 4 from a previous job, and i'm currently trying to find a way (using software) to flash this clean dump instead of opening this one up and pulling the chip.
                FWIW, using the ROL securebootdebug policy, i've been able to launch an EFI shell. i can't seem to figure a way to flash the eeprom from the EFI shell, and MS doesn't offer an EFI firmware update utility like many other vendors do.
                This isn't Monaco... This is Baghdad
                  Re: Microsoft Surface Pro 4 UEFI Unlock Request
                  No, I never got anywhere with it as far as unlocking the BIOS. Other than that it worked fine in Windows, but I ended up not using it very much and sold it to someone else on eBay.
                  The BIOS is pretty limited in settings you can adjust anyway on those devices. So you aren't missing much even if you are locked out of it, basically just secure boot. I think if I get another device in the future it will be a regular laptop.
                    hi if i send my bios can you unlock?
                      Re: Microsoft Surface Pro 4 UEFI Password Request
                      hellow friend , i have an isue with my surface pro 4 wich i did format all the partition and now it wont boot to any system neither will it boot from a pen drive but insted goes to the uefi wich is protected with a password i dont know, any help plz
                        has anyone had luck unlocking the bios dump?
                          Hey I have a dump of my bios which is uefi locked. Can anyone help me?
                            Surface pro 4 UEFI Reset
                            Does anyone have knowledge in how to clean a bios dump?
                              microsoft surface pro 4
                              need to remove efi password
                                Re: microsoft surface pro 4
                                anyone can help?
                                  still waiting
                                    can anyone help regarding this
                                      try this one.
                                        no luck it still showing same ....uefi setting locked with password
                                          anyone can help
