Please help me remove SVP for Dell Precision 5570 suffix 8FC8. Thank you.
Need bios dump Dell Precision 5570
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Tags: None
Re: Dell Precision 5570
Originally posted by Mazorca View PostWhoa, never before seen a bios that big. Anyway, try it now.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Hi
Motherboard LA-L402P
On this dump, diode are flashing.
After uploading from this thread:
https://www.badcaps.net/forum/showth...highlight=5570
it starts and hangs on logo.
There are signs of interference.Attached Files
Re: Need bios dump Dell Precision 5570
try to read the chips again and write your service tag.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Originally posted by siwykk View PostWinbond 25R512JVEN it is well read.
ST: 357FKN3
Excuse my ignorance, I didn't see this chip before.
Will try to do all my best.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Originally posted by siwykk View PostProblem solved. CSME System Tools helped. Topic to be closed.
Regards.
Originally posted by SMDFlea View PostClosed ? ,can you post the working bios to help others
Working dump Dell Precision 5570
Motherboard:
HD051/HDA51 LA-L402P
REV : 1.0( A00 )
RegardsAttached Files
Originally posted by lavie View PostGreetings everyone which programmer did u use to read this chip w25r512jveiq cause mine is tl866ii but it says not supported
WINBOND W25M512JV@SOP16
WINBOND W25M512JV@WSON8 8X6
WINBOND W25M512JV@TFBGA24
WINBOND W25M512JV(ISP)
I used the bin file to write to my bios chip for Precision 5570 when I plug the laptop up the dell icon is displayed but nothing happens but high fans then reboot with 6 battery indicator LEDs flashing 6 times amber colored and then all 6 LEDs flashing 3 times white. The laptop then has white screen and the screen color test then reboots doing the same
Originally posted by Buddyscomputers View PostI used the bin file to write to my bios chip for Precision 5570 when I plug the laptop up the dell icon is displayed but nothing happens but high fans then reboot with 6 battery indicator LEDs flashing 6 times amber colored and then all 6 LEDs flashing 3 times white. The laptop then has white screen and the screen color test then reboots doing the same
Originally posted by Buddyscomputers View PostHere is the file that I read from before I wrote
Here is the new build bios on factory mode
