dell 3420 cyborg-L14 mb 203068-1 help me with this bios
    could you help me with this bios does not give an image does not turn the fan either
    Re: dell 3420 cyborg-L14 mb 203068-1 help me with this bios
    Latitude 3420
    Become a Badcaps supporter
    Thanks to all supporters.
      Originally posted by hoaca388 View Post
      Latitude 3420
      it does not turn on with that programming
        This file from other laptop
          with that it turns on but without image and the fan very fast
            Again
              Again
              with that it does not turn on
                working this file , no image means check power led blinking ,
                  I have Dell 3420 with lock,
                  someone can unlock this model?
                      thanks vesko
                      its working great
                        Hello everyone, I need help unlocking this same bios . I tried a rom that was unlocked and replaced ME region using uefitool but the machine wont even turn on after replacing ME... thanks in advance..
                          Here
                            Worked! Many thanks, is there any chance you can pointme in the right direction to learn how patch these files...?
                              this file proved to me that the bios chip is fine , as i have dell 3420 cyborg-L14 mb 203068-1 which have mdm , i thought i can remove it by editing the bios, didnt work for me so i flashed back the backup file but the backup dump file is damaged( based on trying your file ), the laptop starting with sold colours then off, but with your file it boots , but i have problem , the laptop with your file not charging, what can i do in this case?
                                dell 3420 cyborg
                                  dell 3420 cyborg
                                  thank you , with the previous file you uploaded the battery had 20% , the laptop did not detect the charger, didnt even worked bluged charger without battery, so if i disconnect the battery and use the charger only the laptop acts dead, laptop with battery connected is fine comes on and drainnig the battery obviously like normal laptop but without charging, the laptop gone dead as the battery flat now, now with your new file the laptop act the same , the battery is flat , so now the laptop not coming on at all, any suggestion pls? the laptop was charging before removing the chip
                                    dell 3420 cyborg
                                    sorted thank you
                                      Thank 😊lot brother
                                        please removed bios password
