Marshall Stanmore Repair
    Re: Marshall Stanmore Repair
    Intersting follow up: after placing the bluetooth module back in the Stanmore, all seems to work again. Guess the module had to get a proper connect somehow.
      Can somebody tell me what the value is of L13? Turns out while assembling everything together, this one was broken (no burn marks). Can't exactly tell what the colours have been. Looks like it is similar to L7 next to it but I'm not sure.
      Is this an inductor?
        Originally posted by Chris_J View Post
        Interesting thread. I have replaced the burned R23 (220 ohm) with a bigger resistor underneath the PCB. I have attached a picture so you can see how I have done it.
        I have also a picture for you who have problems finding the 3.3 uF capacitor.
        PS still broken but faultfinding is still in progress.
        Hi My 3.3 uF Cap seems to be reading short, it looks like this goes to a winding on the transformer,could this be the problem? Has anybody changed the transformer on their stanmore?
          Hi
          If someone needs a New working board Marshall Stanmore Main PCB, it can be bought at this link:
          https://reverb.com/item/48237590-mar...e-main-pcb-cpi
          I bought the last one and everything works, the board is completely new
          If someone needs it too, Marshall Stanmore Front Panel with PCB (cpi)
          https://reverb.com/item/48234877-mar...l-with-pcb-cpi
            Hey Guys,
            has any one found any diagram or schematics for this PCB?
            I have 2 of this Stanmore on my table with the same issue, both light up and everything work except from no sound output.
            the area around OB2269 looks a bit hot but I wasn't able to find the OB2269 in our local stores, couldn't find it on digi-key as well, any help or more information is appreciated.
              Originally posted by SkyHeart View Post
              Hey Guys,
              Hi
              I don't know where you are looking for this chip ,but there is a lot of it on ebay in europe
              https://www.ebay.de/itm/223882780254...kAAOSw-xJisx1S
              https://www.ebay.de/itm/133518480526...gAAOSw7dth4q19
              https://www.ebay.de/itm/361705477744...QAAOSwCehi36eR
                Originally posted by kros View Post
                Thank You @kros, yes I found it on ebay after posting and I did order it, though i'm not sure if the cause of the issue is from that IC but it's good to have it just in case
                Thanks again.
                  Thanks again.
                  For me, the best option was to buy a new motherboard, in mine there was a burned hole in the laminate where the TAS5342A chip is, it was completely burnt. Earlier I wrote to marshall asking for a new motherboard, they said they can't sell me, but they can fix it, it will be around 200 euros plush shipping costs
                  That's why I was able to buy a new motherboard for half the price that Marshall was offering
                    Update:
                    The power amplifier was fried and the 7812 IC together withthe shorted D7 located underneath. Everything replaced except the amplifier.
                    The unit started up and this time the bluetooth worked as well Could easy pair it so there is hope for the unit but we see when I receive the power amplifier.
                    The amplifier IC has the marking 42TTI A87CG4 (?) but someone else suggests that it could be a TAS5342A IC?
                    Has anyone information what the amplifier IC could be?
                    Hey @Chris_J
                    were you able to fix your issue?
                    I also replaced 7812 IC and the D7 including the TAS5342A IC, R23 and 3.3 cap but still no sound, I can pair with bluetooth and everything seems to work but still no sound coming.
                      Hey @Chris_J
                      Hi.
                      My friend bought this IC from two different sellers they were new, At the first seller after replacing this IC there was no sound , bought 2 pcs and none of them worked, when he bought from another seller another two IC the IC was working properly, my friend said that there are a lot of fakes of this IC . And you have to be careful when buying.
                        Hi.
                        Thank you kros for the information,
                        I got the amplifier IC's from mouser.com which is a very known website for selling electronic parts so I don't think they are fake.
                          Hi Folks,
                          I was finally able to find the issue with my Stanmore, after changing the 12v regulator which is in the middle of the PCB (KIA 7812A) i found out that it's not getting any input current, had to remove it again to trace the input which is feed by L7 it looks like a normal resistor it was a bit toasty, I'm not sure why the numbering on the PCB says L7.
                          my issue is number 2 from the first post, everything works without sounds output.
                          I changed that L7 with a normal 47ohm resistor and I got sound.
                          attaching a picture of L7 location.
                            I think it's an Inductor not a resistor, for me it's the first time I see an Inductor in the shape of a resistor
                            it's been a while since last time I worked with Electronic it's been more than 15 years.
                            thanks for the help guys.
                              Hello Guys,
                              it's me again trying to fix this Stanmore speaker mess, after changing a lot of components I was able to fix the power issues, the speaker comes on, lights are on, Bluetooth connects fine, when I play music sound comes for few seconds then I will hear 2 or 3 loud static from the speaker and sound disappears.
                              if anyone had a similar issue and was able to fix it please do share the information, I did change the TAS5342A IC.
                                Hello guys,
                                R96 is burn can you help me with its value?Thx
                                  Originally posted by DeeJayAlex View Post
                                  Hello guys,
                                  can you post a picture of the location?
                                    did you ever figure out the values/types of the three diodes ?
                                    I have the same problem.
                                    And lots of leaking caps.
                                    Regards
                                      Hello guys,
                                      on mine R96 is 10kOhm, (labeled "01C")
                                      Do you know / could you check the values of ZD1 and ZD3 please if it is still open ?
                                      Regards
                                        The Location of R96
                                        Thx.
                                          Regards
                                          Thank You for reply!
                                          ZD1 and ZD3 seem to be ok(0,7mV on diode check)
                                          they are zener diodes, which unfortunately I don't know what value they are
                                          Soon I will start to repair it and if it is successful I will check the voltage drop of the zener diodes so that we can figure it out and I will let you know.
                                          Regards.
