Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    Hello, I hope someone can help. I need EEPROM dump for Sony TV XBR-75X940D. Main board BM1 # 1-980-833-11 (173611611) dump needed for IC9017 (PIC16F527-I/SS) It is 20pin IC SSOP20. your help will be highly appreciated.
      Originally posted by lotas View Post
      finlux_40flhz274sc
        i need firmware for Toshiba 24W3753DG TV
        Board: 17MB110P-pn 23451047
        LCD: VES236WNTC-2D-N01
        The TV only flashes red and green. Do you have recovery software for the specified TV? If possible, the installation procedure.
        I can't find anything: - ((((
          i need firmware for RCA 32
          Board: TP.MS3393.PB855
            What's the problem with the TV?
            Post your non-working firmware dump here.
              TV starts normally when put in Smart mode TV shows this ...
              TP.MS3393.PB855
              I need the firmware if anyone has them please
              ⚠ This Firmware is damaged ⚠
              Non-working firmware dump: https://www.mediafire.com/file/pm7ri...6S-SM.BIN/file
              32 inches
              modelo: RCA32A16S-SM
                Your software is fine, I cut off the eeprom now try to write it down
                if it fails, replace the SPI Flash with a new one.
                  TP.MS3393.PB855
                  32 inches
                  Does the TV itself support Smart?
                  He then had to have NAND or EMMC memory.
                    NAND GODDAMN!!!
                    it also has an android subsystem
                    Not everything is lost
                    someone in this forum was asking for this firmware for this board, there it is tested and working
                    Originally posted by javox View Post
                    hola , me prodran ayudar con el firware de la pantalla cobia TP.MS3393.PB855 se los agradecere mucho. salu2
                    Originally posted by aquilesy View Post
                    Hi, please your help, I need eprom dump for TV RCA Model RC4001-A board Nro TP.MS3393.PB855
                    32 inches
                    Model: RCA32A16S-SM
                    https://www.mediafire.com/file/5r88m...nches.rar/file
                      The firmware on your TP.MS3393.PB855 is ok, you need to look for the usb firmware on the android module or somehow enter recovery and do a reset.
                        i hope some one can help
                        i need dump for Soniq L32V12A 32" LCD
                        thanks
                          thanks
                          main board ST306PT-T7
                            Ciao
                            Tv lg47le5308
                            Main. Eax61766102(0)
                            Pannello lc470EUH
                              Zenon ZN-AHD-5016 software
                              Zenon ZN-AHD-5016 software is needed. 25L12835F used. Fault: The device is stuck in the text zenon. There are all voltages.
                              Mainboard: GM8210-AHD-16CH
                              Flash ıc: 25L12835F
                                hi.
                                i need emmc dump
                                sony
                                kd-49xe8096
                                main
                                1-981-326-12
                                (173633712)
                                GN3TR
                                thank you
                                The TV turns on and shows only the SONY logo.
                                I found
                                KD-55XF7596
                                KD-43XF7596
                                nothing changes, after resetting it needs to be refreshed via usb, and again only the SONY logo
                                  Originally posted by Snazzysmith View Post
                                  Sorry didn't make notes on board number.
                                  Please I need LG 42LB5RT eprom firmware
                                    ٍٍSony BRAVIA® KDL-40EX500
                                    System Software Update (version 1.514)
                                    May Be Useful and Help
                                      Originally posted by bboykes View Post
                                      hi anyone got digihome 40272sm eeprom Vestel 17IPS71
                                      You give the model of the power supply without giving any details of your screen or your main board. Unlikely anyone would be able to help you with the lack of information supplied.
                                        Thank you
                                          JVC LT-50C550
                                          UK model 55" TV
                                          Screen - V500HJI-PE8
                                          PSU - TV5001-ZC02-01
                                          Main - MSDV3255-ZC01-01
                                          TCON/Panel - Innolux V500HJI-XRME1 / V500HJI-PE8
                                          NAND - Toshiba TC58NVG1S3HTA00
                                          From a working TV that had LED backlight strips replaced.
                                          No password, 2 part rar.
