DMR115 , Makita on site radio
    Hi all
    Trying to take this thing apart & there are 2 screws buried deep in the back of unit .
    Look like torx of hexagonal heads .
    Can anyone help with type & size of driver required ?
    Re: DMR115 , Makita on site radio
    Depending on what country you live in but if you live in the USA you can go to Harbor Freight and buy a set of all kinds of bits and there should be one that fits
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      Thanks Sam
      Pulled up the exploded view , & seems to use M3 HEX type screws
      Ordered a 4 piece set of long bits from Ebay .
      Hopefully one of them will fit .
        Contrary to exploded view ,the head is actually a Torx type .
        It's a TX15 & needs to be a minimum of 100 mm in length to reach screw .
        How do i know ? , well ended up sacrificing a long HEX 3 mm bit , which i filed down enough to grip screws , then remove them .
        Now to deal with no power issue .
        Schematic would be handy
          Discovered an SMD fuse O/C , next to connector CN4 .
          Might be lucky for a change .
          I would gauge it's value at just over 3 AMP , as battery is rated at 3 AMP & the charger 2.5 AMP .
          Will replace it & hope for the best .
            Fuse marked T , which is 5 AMP .
            Replacement restored power
              that screw is a security-torx,
              what a bunch of fucks!
                A lot of stuff I open lately have that security torx screw.
                  yes, but they arent usually used in deep recesses - i find tri-wing in those types of casing
                    wait till you find the custom ones that only the manufacturers have the correct tools .
                    such as these ..
                    https://www.fastenright.com/brand/ultra-drive
                      lol
                      a lot of those can be opened with a small flathead.
                      the ones with dimples i open with a flathead with a notch ground out of the center
                        Wow Peter
                        As if this trade wasn't difficult enough
                          adapt and overcome.
                          i have lots of cheap screwdriver sets from £ stores.
                          i dont care if i have to file or grind them to fit a specific job.
                            Yes , we are quite resourceful
                              I have the same problem, replaced the fuse, works fine, but now only way to switch off the radio is to remove the battery.
                              Any ideas why this would happen?
                              Many thanks
                              COYI
