Question about bipolar electrolytics
    Good morning all,
    Is it true that all the bipolar electrolytics are made/manufacturered of two "back-to-back" polar electrolytics in the - + + - configuration, and that would explain why they are usually larger than equivalent value of a common polarized electrolytic? (e.g. Muse UES)
    N.B.: polarized Silmic II are also usually larger than common electrolytic, though.
    Re: Question about bipolar electrolytics
    who cares, it's better to replace them with polyester or polypropylene anyway - just more expensive.
      What about BP caps of 220uF or larger?
        never seen one.
        they probably are very expensive and hard to find too - so still possibly a way to use foil instead.
        specially as most BP caps are running below 100v
          Originally posted by Cap_search View Post
          Good morning all,
          I think not. Bipolar electrolitics are also built as single capacitors with both the anode and cathode foils oxidized.
          Back-To-Back vs. Single Cap. is more or less the same but purists swear that the second one has better characteristics. For sure there is less ESL if the capacitor is a single one and lower E.S.R. is also possible.
            That's what I thought, too. Just wondered they are usually bit larger than normal polarized equivalents. Grazie.
              Usually the non polarized caps that are larger in size handle larger currents, as an example are the ones that were used in the horzontal yoke section of monochrome tv's & monitors. I still have some Rubycon 6.8µf/50v (18mm x 40mm) I have seen people replace them with regular 6.8/50v nonpolarized and after a few minutes of running the cap heats up and removes itself from the chassis.
                nearly fell of my chair laughing then ... and of course higher voltage ones are bigger . strange thing i once used a polar cap for testing something that should have had non polar fitted .seem to remember it was starting a motor or something .it worked just fine on AC .
                  Higher current ones "of the SAME capacity and voltage" are a lot bigger.
                  I've seen other shops/customers replace the cap with the type normally found in cheap crossover's
                  IE: 10µf/50v (6mm x 12mm) for the one I described, and they can't handle the high current. They would look at the capacity and the voltage and figure it should work. They would think there must be a fault somewhere else, They would eventually bring it to our shop and after seeing what they did I would install the correct cap and that was it, fixed.
                    I think physically bigger electrolytics have higher ripple current rating because they can get rid of the heat better.
                    One problem using two polarized electrolytics to make a bi-polar one, is the two capacitors are always mismatched i.e. 9uF and 11uF so the smaller cap can end up seeing reverse voltage, if low frequencies get passed through.
                    The midpoint is supposed in theory be zero but you get voltage there, and the cap eventually causes distortion and then shorts. So I don't make them this way anymore.
                    Lately, I always change out bi-polar electrolytic caps for film caps.
                      Someone on this forum mentioned once that they eventually become polarized.
                      Mr. Carlson on Youtube also has a video on how film caps really are actually polar caps.
                      I guess the only real non-polar caps are ceramic.
                      Every time I come across an NP cap in a circuit, I wonder to myself if it would be possible to re-design the circuit without the need for one. They're very common on modems.
                      "We have offered them (the Arabs) a sensible way for so many years. But no, they wanted to fight. Fine! We gave them technology, the latest, the kind even Vietnam didn't have. They had double superiority in tanks and aircraft, triple in artillery, and in air defense and anti-tank weapons they had absolute supremacy. And what? Once again they were beaten. Once again they scrammed [sic]. Once again they screamed for us to come save them. Sadat woke me up in the middle of the night twice over the phone, 'Save me!' He demanded to send Soviet troops, and immediately! No! We are not going to fight for them."
                      -Leonid Brezhnev (On the Yom Kippur War)
                        the film caps that are uncased that have a stack of layers with end terminals - the silver ones.
                        those wont be polarised.
                          Mr. Carlson talks about (wound) film caps being "polarized" as far as the outside wrap and a marking stripe on the case.
                          It's desirable to have the outside wrap connected to the output of a stage (not input), kind of acting like a shield. But this is only for high-impedance tube gear from days long ago.
