how to solder NEC TOKIN IC 0E907 ( conductive glue ???)
    Hello
    I need to remplace NEC TOKIN 0E907 for acer laptop but i can t use the airflow gun because the nec tokin ic burnt. And for low temperature <220° the solder paste don't heat. it's low
    I seen we can remplace it with 4 x 330uF smd but i want remplace it with original ic.
    Can i use conductive glue (which product) or an other solution?
    Thx
    Re: how to solder NEC TOKIN IC 0E907 ( conductive glue ???)
    you need a real reflow station - and then it can fail again.
    use the 330uf polymers.
      sorry i ve an Digital Hot air Station and not airflow gun that i wrote.
      I feel that the tokin was glued and not soldered because I can tear it off the motherboard
      i tried with 330uf the laptop is good working but i want a clean working for client
      thx
        well most laptops use the 330uf caps, the tokin caps are a failure and kill a lot of PS3's too.
          Originally posted by lepak06 View Post
          (...) but i want a clean working for client
          That's an epoxy glue type (probably black color).
          I always remove it by scratching and peeling it off. Then use a solvent to remove any smaller lefties.
            seems the recommended repair is an upgrade .. i dont think the customer wants to look at that bit .
              most repairs are an upgrade, because you dont want the blame for it failing again.
              that's why we dont replace shit caps with more "chong-x" or whatever, but spend the extra on panasonic or use polymers.
              a good repair is a repair you only do once!
                PMSFL.!! TOO TRUE, cheap china caps always fail.
                  Exactly!!!
                  Skip the NEC TOKIN caps and use something else - SMD polymers, tantalums, ceramics... whatever. just NOT those NEC TOKIN c[r]aps.
                  The customer will likely never look inside the unit and hence never complain, as long as the unit is working. And if they do, you can always tell them why you didn't use original replacements.
                  As stj mentioned, many PlayStation 3 consoles and also a few older Toshiba laptops were affected from these failing NEC TOKIN caps.
                    I've done dozens of these. Always 4x330uF on Toshiba. Only on Acer 6930G/8930G I do 4x 470uF or 6x 330uF because 4x330uF is not always stable.
                    A working TV? How boring!
