Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Audio Equipment
Thread Tools Display Modes
Old 05-16-2019, 05:57 PM   #21
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Default Re: Harman Kardon AVR 270
Yes, I scrolled up too far to the Center channel
If R723/725 are open transistor could be bad, also check the base resistors, R647/652, then work back checking the driver transistors and resistors. comparing same components to a working channel is helpfull sometimes
R_J is offline   Reply With Quote
Old 05-16-2019, 07:08 PM   #22
playman
City & State: Iceland
My DCA55 says that there is a short between Collector and Emitter on Q652 trans.
The other two seem to be ok.
Will be testing rest of the stuff tomorrow.
playman is offline   Reply With Quote
Old 05-17-2019, 06:54 PM   #23
playman
Just finished testing all the components in that channel.
Nothing out of the ordinary as I could notice, except for one Diode.
D582 measured 400kΩ and rising when positive probe was on cathode, other Diodes
did not do that, trans Q652 and the two resistors R723 and R725 are not installed.
Q882 and Q871 seemed ok.
I did not check the To-92 Transistors though.
Capacitors measured fine with the ESR meter, did not check the ceramic ones though.
Old 05-17-2019, 07:39 PM   #24
R_J
City & State: ☻
My Country: Canada
You could lift one end of D582 to check it, Check the transistors like Q562, Q502, maybe they have some leakage.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
