hi, does anyone know the value of this resistance located in F3?
resistance burned adp 240 ar power supply ps4
Re: resistance burned adp 240 ar power supply ps4
im not sure but maybe ask on this group f3 i think is a fuse have you tested other parts for shorts as thats parts blown for a reason.
https://www.facebook.com/groups/ps4repair101/
Edit!! ive asked on this group for advice as im a member.Last edited by vinceroger69; 08-25-2018, 06:32 AM.
Originally posted by diif View PostI've got a ADP 240CR here.
Colours look to be brown, blue, silver, gold. Has continuity like a fuse.Last edited by vinceroger69; 08-25-2018, 07:17 AM.
You should upload good clear hi-res straight shot pictures of the whole top and bottom side of the board so we can see how that resistor connected in the circuit.Never stop learning
Originally posted by reset1986 View Postthanks to all, is a low resistance 0.16 ohms that serves to protect 2 mosfet q2 q3 with the initials TK12A60U, these are short, check also IC DDA001AG that is not shorted to be successful
My daughter turned on the PS4 (inital launch version, approx 5.5years now). After the “beep” to turn on, there was a loud bang sound.. opened it up and F3 is toasted - as attached.
The PS4 is only plugged into power when used (about 2hours a month). There are no evidence of bugs or much dust, photos taken without any cleaning/dusting.
I am not sure the cause of the bang, the power suppies (non oem) are about $50AUD, might get that instead...
Originally posted by Twobit View PostDid you have a part number at all that I could use to search at Australian stores (jaycar or rs-components)?
Also, that resistors seems to be connected to the MOSFETs for the main PS section (Q2 and Q3), so those might be blown too.
Originally posted by Twobit View PostThe PS4 is only plugged into power when used (about 2hours a month).
Originally posted by Twobit View PostI am not sure the cause of the bang
Originally posted by Twobit View Postthe power suppies (non oem) are about $50AUD, might get that instead...
Originally posted by momaka View PostI tried looking on RS components AU, and couldn't find anything that matches for you. Even eBay didn't offer that much choice, which was a surprise to me. But I imagine if you can't find a 0.16 Ohm 2W or 3W metal film resistor there, perhaps going with 0.15 Ohm 2W or 3W metal film should be OK. Just make sure to go with metal-film, as they are typically flame-resistant/proof and/or fusible.
The attached image is from the distributer the shops I found are wagneronline.com.au and aztronics.com.au.
The ps4 used to be plugged in but I travel several weeks at a time and when away most of my “toys” are left off to save standby power and the off chance of storms while I am away.
On this particular event, we had played an hour the day before and was left plugged in. The daughter wanted to pay a game that needed an accesory and was about to plug it in when it went pop, she got a big fright.
Originally posted by Twobit View PostThanks for the help. I found a few places (sadly interstate so $10postage) which have the Fusable Resisters. The 1/2W suggested above seems a bit low and looks thin. They have 0.15 and 0.27 ohm options which seem close enough given a 5% tolerenace. I am just unsure on the wattage.
Originally posted by Namen Victor View PostMine has no Continuity, and no burn marks. Can I replace it with a Wire ?
Those low resistance resistors have a very important purpose - they allow the controller to determine how much current is going through the primary side. They are also usually fusible, meaning they (should) go open-circuit to protect more damage to other parts.
Replacing it with wire is not a good idea, even just for testing purposes.
Hello, I have a faulty ADP-240AR for which I had to replace two mosfets as these showed continuity on all three pins and I also replaced an IC DNP015 (i saw a youtube video) but still the power supply doesn't bring up the 12V rail when trying to power on.
Now I saw the F3 and I measured it and it has no continuity. It looks like a resistor but it says F3 so it must be a fuse and I think it is broken as it has no continuity.
Mine has the colors red, blue, silver and gold (0.26 Ohms).
Does anyone have a URL where I can buy these online ?
I have been searching al day but can't seem to find these things.
Do you have local electronics repair shop that you can ask and see if they have anything?Never stop learning
