Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Old 09-09-2019, 01:30 PM   #21
newguy90
City & State: Zalau
My Country: Romania
Unhappy Re: Using my CH341A.
Originally Posted by R_J View Post
I found this information on using a CH341a and 93LC86 microwire https://freesoft.dev/program/171504972
93C56b is microwire
thank you R_J. I followed the link you gave me, but the info found there it doesn't help me... As far as I know the 93C56 EEPROM of my car has a bit organization of 128x16 bits, not 256x8 bits. The project from the link you sent me has a limitation in this respect (only 8-bit data organization (ORG pin Low) supported).
newguy90 is offline   Reply With Quote
Old 09-09-2019, 04:52 PM   #22
stj
stj's Avatar
City & State: Europe
Default Re: Using my CH341A.
maybe you should look at PONY PROG,
Old 09-10-2019, 12:48 AM   #23
newguy90
City & State: Zalau
My Country: Romania
Question Re: Using my CH341A.
I've started looking yesterday on the Pony prog 2000 website. As far as I see, I need to build the Base board (SI Prog) + the 93cxx adapter (Microwire eeprom adapter) using the schematics provided on that website. Is that right?
I want to build those, but as simple as it can be... So what would be the simplest schematic that I should build? Do I really need the extra power source? And if I do, can I use the 5V rail from the PC's PSU for this purpose instead of the one presented on the Base board schematics ?
Old 09-10-2019, 02:52 AM   #24
stj
stj's Avatar
you only need what will be used, so really just 5v
Old 09-10-2019, 04:04 AM   #25
newguy90
City & State: Zalau
My Country: Romania
I inverted in the image below the colors of the components which I want to remove from the Base Board interface, and I retraced with red color the connections that I think it needs to be done in the circuit. Would it work this way?
Old 09-10-2019, 09:02 AM   #26
stj
stj's Avatar
you need the voltage regulator, the serial port outputs 12v.
well it should but modern stuff is closer to 9v but it will still fry your chip!
Old 09-10-2019, 09:03 AM   #27
stj
stj's Avatar
or get 5v from a usb port.
Old 09-10-2019, 01:08 PM   #28
newguy90
City & State: Zalau
My Country: Romania
I see... If 12 V is the voltage from those serial pins, then I think I definitely need a 5v regulator... But if I don't have the 5 V regulator (LM2936z-5), what else can I do using other common electronic parts that are easily available? Or can I just eliminate the 1N4148 (D1, D2 and D3) along with the regulator and the other capacitors (C3, C4 and C12) and just use a 5V from USB or from an 5V PSU rail to drive the pin 1 (that's VCC, + PE + ORG of the 93cxx EEPROM ) ?
Old 09-10-2019, 01:17 PM   #29
megaraider
City & State: Porto
My Country: Portugal
I'm a: Hobbyist Tech
You can salvage an LM7805 from any common domestic appliance, TO-220 easy to spot.
You can also find 5V regulators in 3.5" hard disks boards.
megaraider is offline   Reply With Quote
Old 09-10-2019, 01:21 PM   #30
megaraider
City & State: Porto
Pay attention to the EEPROM pin layout:
93C56B-I/MS standard pin layout
vs.
93C56BX-I/SN rotated pin layout
Old 09-10-2019, 02:18 PM   #31
stj
stj's Avatar
just use 5v from usb or ps2 connectors.
Old 09-13-2019, 12:06 PM   #32
mcnc
City & State: Krusevac
My Country: Serbia
Does this flasher supports 1.8v chips?
mcnc is offline   Reply With Quote
Old 09-13-2019, 08:17 PM   #33
stj
stj's Avatar
no, it supports 5v chips, it's not intended for large chips like serial-flash
Old 09-16-2019, 01:56 PM   #34
el panke
City & State: buenos aires
My Country: argentina
Line Voltage: 220v
this is the last ver of the software
maybe could help some1
el panke is offline   Reply With Quote
Old 09-19-2019, 03:21 AM   #35
newguy90
City & State: Zalau
My Country: Romania
Cool Re: Using my CH341A.
I uploaded your archive to virusTotal to verify it and some AV engines have detected trojans. ( CAT-QuickHeal : Trojan.IGENERIC /// MaxSecure: Trojan.Malware.74274250.susgen // SecureAge APEX: Malicious//
SentinelOne (Static ML): DFI - Suspicious PE//Trapmine: Malicious.high.ml.score)
Are they just false positives, or what?
Old 09-19-2019, 08:24 AM   #36
stj
stj's Avatar
hard to know, the hacked versions are loaded into some type of "virtual shell" so the software thinks it's on a different machine.
you could hide anything in that.
it still wont do 93 series.
Old 09-20-2019, 03:39 AM   #37
newguy90
City & State: Zalau
My Country: Romania
Well, I did it! I built myself a Pony Prog adapter for the programming of 93cxx EEProms using PonyProg and the result is: SUCCESS! I managed to write a 93c46 EEPROM that I bought from a local shop for testing purposes.
Next: I will try to read/write the 93c56 in circuit. Keep ur fingers crossed for me, pls !
Old 09-20-2019, 05:28 AM   #38
el panke
Line Voltage: 220v
just false positives i guess, never had a problem using it
Old 09-20-2019, 06:02 AM   #39
stj
stj's Avatar
to read in circuit,
you have to power the circuit, and make sure nothing else try's to read the eeprom when you do.
infact if your doing that, DONT connect the 5v supply pin to the eeprom.
just the ground and clock/data etc.
Old 09-24-2019, 01:42 PM   #40
newguy90
City & State: Zalau
My Country: Romania
I successfully read and wrote in circuit the 93c56 and 93A56 EEPROM's. I didn't have to power on the circuit, I just used the SOIC8 test clip with the interface
that I built!
I could not use the CH341a though, so I have no use for that interface... at least for now.
Badcaps.net Technical Forums 2003 - 2021
