Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 02-11-2020, 10:51 AM   #1
LITEZONER
GO BOLTS!
LITEZONER's Avatar
City & State: Temecula CA
My Country: USA
Line Voltage: 110V 60Hz
I'm a: Knowledge Seeker
Default LG 42LN5700 issue
Hello all, Just replaced all the LED strips in this set, during diagnostics I shorted out the power supply by arcing it against the chassis, so changed that too, the main board was missing one of the HDMI input connectors, so I changed that as well, I know, I know, should have just bought another set, this thing cost me $599 bucks, so I think it was personal. LOL, cost me around 120 for everything Iv'e done so far, But my issue is this. I have two wide strips of a yellow or bright hue going vertically on either side of the center, it's like racing strips if you will, it is so faint I'm not sure i can even get a picture of it to post, I was thinking the obvious t-con board, but could also be the LVDS cable, and other causes you can think of? would a bad panel cause this? when the led went out it literally seemed like it blew up with significant burning on the strip itself as well as the plastic strip cover, it also has burn marks. didn't know they could do that.
__________________
39 Soldering Iron burns And Counting
LITEZONER is offline   Reply With Quote
Old 02-11-2020, 11:49 AM   #2
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Default Re: LG 42LN5700 issue
That is minor, I have seen them burn up the white plastic sheet in side the panel. I have also seen a samsung led strip short and shut down the power supply (but the power supply was ok)
Check the cables between the panel and the t-con and make sure there is not a damaged conductor on the flat cable.
But in this case I suspect you may have damaged the tab connection to the panel. Either the thin flex cable is bad or the cof ic is bad,
R_J is offline   Reply With Quote
Old 02-12-2020, 09:13 AM   #3
LITEZONER
GO BOLTS!
LITEZONER's Avatar
My Country: USA
I was super careful with those tabs, I'll recheck the connections at the tcon and see what I get out of it, not sure how to repair bonded ic's
Old 02-12-2020, 10:58 AM   #4
LITEZONER
GO BOLTS!
LITEZONER's Avatar
My Country: USA
Default Re: LG 42LN5700 issue PICS
managed to get some pictures of it.
Old 02-12-2020, 11:20 AM   #5
R_J
City & State: ☻
My Country: Canada
That does'nt look like a tab issue, it looks more like a diffuser issue, Are you sure you installed them back the same way?
If it was a tab or driver issue, the edges of the bands would be sharply defined.
Have you tried your original main board to see if it changes anything?
Old 02-12-2020, 11:39 AM   #6
LITEZONER
GO BOLTS!
LITEZONER's Avatar
My Country: USA
have not tried original main board, will do that and reply. thank you I leaned everything against the wall behind the set when I replaced the led strips, stacking in order against the wall i should say, Making it nearly impossible to arrange diffusers in any sort of incorrect order. Kind of wondering if the back being off and some of the holes in the metal frame letting light escape in certain area's, anything like that sound possible? just spit balling here. LOL
Old 02-13-2020, 04:24 AM   #7
mmartell
City & State: Windsor ON
My Country: Canada
The obvious question here is are your strips mounted vertically and if so does the colour shift line up with where the strips are ?
Also were there any plastic spacers under the screen and were they replaced ?
mmartell is offline   Reply With Quote
Old 02-14-2020, 06:03 AM   #8
LITEZONER
GO BOLTS!
LITEZONER's Avatar
My Country: USA
no spacers in there, strips mount horizontally and are staggered from strip to strip which I found odd, the others Iv'e done all the led's lined up in rows vertically in line
Old 02-17-2020, 05:24 AM   #9
LITEZONER
GO BOLTS!
LITEZONER's Avatar
My Country: USA
I guess since you guys think it is probably a diffuser issue I am going to take it down again and have a look, Not sure yet of what possibly could be wrong, But I will report any findings, or maybe document disassembly and reassembly?
Old 02-17-2020, 05:28 PM   #10
R_J
City & State: ☻
My Country: Canada
If you disconnect the lvds cable from the t-con will the backlights stay on? If they will (and the tv stays on) you should be able to determine if it is a panel/signal or backlight/diffuser issue
Old 02-24-2020, 09:47 AM   #11
LITEZONER
GO BOLTS!
LITEZONER's Avatar
My Country: USA
so I did find one standoff that apparently came through by way of tv on its backside, and was floating around in there, I put it back and floated it back together and turned it on, and Unfortunately have same issue, the only difference between the old and new LED strips is that the old one's has a circle of diffuser material around each LED and the new one's do not, But i don't think that would cause an issue like this? going to try R_J's idea now and thank you for that by the way. any other idea's thoughts always welcome, thank you all, Very much appreciated.
Old 02-24-2020, 10:00 AM   #12
LITEZONER
GO BOLTS!
LITEZONER's Avatar
My Country: USA
Backlights do come on, Bright at first, then not so much but still visible. so here are some pictures with T-Con disconnected, so this points to Diffuser issue? should I take each piece of diffuser out, clean it and reassemble? I'm perplexed now, what else is new though LOL
Old 02-24-2020, 10:14 AM   #13
LITEZONER
GO BOLTS!
LITEZONER's Avatar
My Country: USA
here some pics with panel removed forget the Horizontal flicker, it;s the vertical discoloration I cannot seem to find the cause of.
Old 02-24-2020, 10:22 AM   #14
diif
City & State: Midlands
My Country: England
It could be the missing reflective circles. The darker bits are perhaps on the bends on the back metal sheet. The pattern is to even to be anything else.
diif is offline   Reply With Quote
Old 02-24-2020, 10:25 AM   #15
R_J
City & State: ☻
My Country: Canada
If the bands are still there with the lvds cable disconnected, the fault can't be caused by a video issue, so this eliminates the main, tcon and lcd glass itself. It won't be a cleaning issue and cleaning may cause damage. Make sure the diffusers are in properly. The first one closest to the led's should be the thickest and have the dimples toward the led's.
I would remove the thin diffuser sheets and only place the thick sheet over the led's and if you still see the bands, it won't be a diffuser issue.
After seeing the latest pictures:
It does seem odd that the led intensity has brighter bands like that.
Old 02-24-2020, 01:47 PM   #16
LITEZONER
GO BOLTS!
LITEZONER's Avatar
My Country: USA
Well, not sure if you guys can see these led strips the way I do, there are discolored bands in them, almost a blue color going vertical on the left, right, and center. Very weird, let me know what you think of this
Old 02-24-2020, 04:08 PM   #17
R_J
City & State: ☻
My Country: Canada
Where did you get the strips? usually when the led's start to show blue they are at the end of their life. even in the pictures I can see a difference in the led intensity from one to another, this should not happen.
Old 02-24-2020, 08:44 PM   #18
LITEZONER
GO BOLTS!
LITEZONER's Avatar
My Country: USA
Thank you all, so much for new led strips on eBay, getting a refund at least.
Old 02-24-2020, 09:36 PM   #19
R_J
City & State: ☻
My Country: Canada
Good to here about the refund, You might have better luck from shopjimmy
Old Today, 12:54 PM   #20
pier12
City & State: Rousse
My Country: Bulgaria
https://www.aliexpress.com/item/4000...archweb201603_
pier12 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
