Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 07-29-2019, 07:34 AM   #1
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default xbox ultimate solid-mod
previously, others have put polymers in xboxes,
but usually not replaced the smd electrolytics or the vrm smoothing.
the main failing caps!!
and often they used oversize caps that dont fit well.
so here is one done right, i call it the XXX-BOX because it's hardcore!
stj is offline   Reply With Quote
Old 07-29-2019, 09:51 AM   #2
diif
City & State: Midlands
My Country: England
Default Re: xbox ultimate solid-mod
Looking good, are they the poly caps you got from Ali?
diif is offline   Reply With Quote
Old 07-29-2019, 10:11 AM   #3
stj
stj's Avatar
everything other than vrm was ali,
vrm came from RS.
but only because i got those first - future boxes will be 100% ali sourced.
btw, while doing this i discovered something usefull.
any FOXLINK psu's - check the 1200uf caps!!!!
Old 08-06-2019, 10:56 AM   #4
Stefan Payne
City & State: Northern Germany
My Country: Germany
Line Voltage: 230VAC/50Hz or 400VAC/3P/50Hz
I'm a: Knowledge Seeker
are that two totally different PCB revisions with some major changes?
Especially the CPU area and Power connector...
Stefan Payne is offline   Reply With Quote
Old 08-06-2019, 04:40 PM   #5
stj
stj's Avatar
there is very little changed between v1 and v1.5
almost exactly the same caplist.
v1.0 has a usb hub on a riser card,
v1.1 and higher has it on the main board.
v1.0-1.1 uses a different power connector to 1.2-1.5
other than that there are 2 or 3 different video encoders used.
but if you compare them the differences are very minor.
Old 10-27-2019, 07:24 AM   #6
Blag
City & State: NRW
My Country: DE
I'm a: Hobbyist Tech
Great work but why did you use tantal caps instead of polys in some places?
Also do you've plans to do the same for the psu as well?
Blag is offline   Reply With Quote
Old 10-28-2019, 06:47 AM   #7
stj
stj's Avatar
the board has pads on it for tantalum caps, but m$ cheaped out during production and only used tants on the underside.
i wont poly the psu - that usually wont work.
Old 10-28-2019, 10:04 AM   #8
Blag
City & State: NRW
My Country: DE
Quote:
Ah alright. Because of the far lower esr of polys? Is this only true for higher wattage psus (xbox and newer) or basically for all psus? I was thinking about replacing the psu caps on some retro consoles, so that would be a real downer.
Old 10-28-2019, 10:49 AM   #9
stj
stj's Avatar
it's true for all psu's,
the most common problem is the psu see's the caps as a short-circuit at power-on and shuts down or goes into a startup-shutdown loop.
Old 10-28-2019, 12:12 PM   #10
Blag
City & State: NRW
My Country: DE
Thanks I'll keep that in mind. Many retro consoles have a external psu and only a small internal power board so that could be fine.
Old 10-28-2019, 01:08 PM   #11
stj
stj's Avatar
yea, anything older than playstation/saturn uses external AND usually not switching but traditional transformer design.
Old 02-12-2020, 09:03 AM   #12
RoroX
City & State: Kopenhaga
My Country: United Kingdom
Noooooice, did you change 10v 3300μF caps to 6.3v 1500μF
RoroX is offline   Reply With Quote
Old 02-12-2020, 11:04 AM   #13
stj
stj's Avatar
yes,
but notice i fitted more of them.
where m$ used 3300uf they left spaces because they had originally fitted 1500 or 1800uf caps.
so the total capacitance is actually similar - but the esr is much lower!
Old 02-12-2020, 03:29 PM   #14
RoroX
Awesome, can tell me the paramets of your tantalum caps?
Old 02-13-2020, 01:38 AM   #15
stj
stj's Avatar
https://www.aliexpress.com/item/32370177546.html
https://www.aliexpress.com/item/32372832101.html
https://www.aliexpress.com/item/32983008282.html
https://www.aliexpress.com/item/32951610902.html
Old 02-13-2020, 11:54 AM   #16
RoroX
Sorry for bothering you, but what are the ESRs of your 25v 22F / 100F caps?
Old 02-13-2020, 09:28 PM   #17
stj
stj's Avatar
i have no idea.
lets just say that they have to be better than the original general purpose crap i removed.
it's not critical there anyway - only for the 1500uf caps because they are smoothing power circuits.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
