ASUS VE247 Help
    ASUS VE247 Help
    Hello everyone, I recently got an ASUS VE247 monitor for free because it was going to be thrown away. It would work fine for a while and then the image would freeze up, lines would appear and it would start turning white. I opened it up to have a look and I couldn't find anything wrong, and I left it apart for a while to see if it would mess up so maybe I could find the problem, but it never would. So I started to put it back together and after I did, it would not turn on at all, so I was hoping I could get some help here because it would be a nice monitor if I can get it working.
    Here are some pictures of the PCBs.
    Re: ASUS VE247 Help
    Can anybody help me out? I've looked at the pcbs and cant seem to find anything wrong. I can post more pictures if needed.
      Re: ASUS VE247 Help
      Ok so it would turn on before messing with it but now won't?
      Have you checked your connectors?
        Re: ASUS VE247 Help
        Yes, I have checked the connectors with a multimeter and there was no power.
          Re: ASUS VE247 Help
          Just to make sure you tested it correctly... Set DMM to 20Vdc and put black probe to chassis (screwhole or something is good) and red into each of the pins on the connector that goes to the mainboard. Post results back like this
          pin 1 - 0v
          pin 2 - 5v
          pin 3 - 0v
          etc
          etc
            Re: ASUS VE247 Help
            Ok, so I tested all the pins and got 0v on all of them. The components I circled in the image are pico fuses right? because I tested them and the ones I circled were bad.
            Thanks for your help
              Re: ASUS VE247 Help
              those are SMT caps... prefix is cXXX
              Fuses will be FXX/16A or similar
              Check your main fuse... the big one next to the large capacitor.
              If ok check voltage at main cap, probe on each lead
                Re: ASUS VE247 Help
                Ok, the fuse was good, I got 381v while it was plugged in, and 97 while it was off.
                  Re: ASUS VE247 Help
                  "381v while it was plugged in, and 97 while it was off" That cannot be right, when it is off, you should have around 160~170VDC right at the two legs of the main cap.
                    Re: ASUS VE247 Help
                    Oops... had the multimeter set to AC lol. I got 173v while it was on, and 40v while it was off.
                      Re: ASUS VE247 Help
                      Those are way off, the chances of that cap being bad are slim!
                      Check your meter battery
                        Re: ASUS VE247 Help
                        I used a battery tester and it said it was bad, so I guess ill have to get a new one tomorrow and try it again. Is there anything else to check for right now?
                          Re: ASUS VE247 Help
                          Did you see this post though, I retested it because I had it set to AC.
                            Re: ASUS VE247 Help
                            Yes i looked at that post, As budm said it should read 160~170Vdc so 40Vdc is way too low, hence i asked about your meter battery
                              Re: ASUS VE247 Help
                              Ok well thanks for the help, ill get a new battery and test the cap again, and report back tomorrow.
                                Re: ASUS VE247 Help
                                Ok, I got a new battery for my meter today and checked again. I still got 170vdc while it was plugged in, and 44vdc while it was unplugged, is it possible the cap is bad?
                                  Re: ASUS VE247 Help
                                  "44vdc while it was unplugged" that is because the cap was diacharging when the power is removed (not plugged into the outlet).
                                  So reading at 170VDC when plugged in is OK.
                                    Re: ASUS VE247 Help
                                    What should I check next? I double checked and the logic board is still getting no power, all the components look good.
                                      Re: ASUS VE247 Help
                                      Sorry for the bump, but its been a while and no one has posted. Can anyone help me out? I can upload more pictures if needed.
                                      Thanks.
                                        Re: ASUS VE247 Help
                                        How would you check the transformer I circled? I tried to check it and I got 170v on one side, and 0v on the other, but im not sure if I did it right.
