Thread Tools | Display Modes |
#21 |
City & State: Arizona
My Country: USA
I'm a: Knowledge Seeker
![]() you can view the waveform signal 20KHz within.............. i'll pass.
i will wait until they update bandwidth to 2MHZ or 20MHZ. Last edited by capwizard; 01-20-2019 at 07:58 PM.. |
#22 |
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
I'm a: Professional Tech
![]() Yeah I don't get the point of that feature, its the sort of thing you can do with a laptop and free software using the sound card if I recall. Well assuming you have the aforementioned laptop, analogue scopes can be had very cheaply now as well.
#23 |
City & State: Europe
My Country: some shithole run by Israeli agents
![]() the point of the feature is to see if the power is stable, or if it's being effected by something.
it's actually very good in some situations. |
#24 | |
My Country: USA
![]() Quote:
I would like to have my next meter with another future is data logging that's what I've been searching for a cheaper and easy to use one. Any suggestion? Datalogging with a Multimeter https://www.norwegiancreations.com/2...-a-multimeter/ Last edited by capwizard; 01-22-2019 at 09:03 AM.. |
#25 |
![]() no, not logging.
if you put a standard meter on a car supply, it will say 12-14v but if you put a meter with a waveform display you can see if the alternator is failing because you can see the dips between the 3 phases. dc is not always a flat-line, even if you want it to be! btw, i have a 22000count meter with a serial port - it's not the same thing. Last edited by stj; 01-22-2019 at 09:21 AM.. |
#26 | |
My Country: USA
![]() Quote:
#27 | |
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
![]() Quote:
But in general the output of an alternator is very noisy to being with any way but the wave form output would be different
__________________
9 PC LCD Monitor 6 LCD Flat Screen TV 30 Desk Top Switching Power Supply 10 Battery Charger Switching Power Supply for Power Tool 6 18v Lithium Battery Power Boards for Tool Battery Packs 1 XBox 360 Switching Power Supply and M Board 25 Servo Drives 220/460 3 Phase 6 De-soldering Station Switching Power Supply 1 Power Supply 1 Dell Mother Board 15 Computer Power Supply 1 HP Printer Supply & Control Board * lighting finished it * These two repairs where found with a ESR meter...> Temp at 50*F then at 90*F the ESR reading more than 10% 1 Over Head Crane Current Sensing Board ( VFD Failure Five Years Later ) 2 Hem Saw Computer Stack Board All of these had ![]() All of the mosfet that are taken out by bad caps ![]() Last edited by sam_sam_sam; 01-22-2019 at 04:22 PM.. |
#28 |
![]() sort-of,
the alternator is a rectified (but not smoothed) 3phase generator. the dips in the output should be evenly spaced, if not then a diode or winding may be bad. |
Thread Tools | |
Display Modes | |
