Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Thread Tools
Old 11-28-2017, 02:28 AM   #861
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Default Re: ESR meter upgrades
On hand, mega8's and a mega328...
Working on layout now with my pitiful single sided board limit...
eccerr0r is offline   Reply With Quote
Old 11-28-2017, 04:47 AM   #862
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
ah, i thought you already had one.
if your going to make one, why not get a colour display from china for a couple of $?
stj is offline   Reply With Quote
Old 11-28-2017, 11:54 AM   #863
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Actually I plan to use only parts I have in my parts collection. I have a pile of HD44780 16x2 displays too, and thus don't think I actually need to buy anything, as far as I know right now.
Old 11-29-2017, 11:10 AM   #864
Adrian_
City & State: Bucharest
My Country: Romania
I'm a: Knowledge Seeker
Guys, out of the current types of El Cheapo ESR cap meters available on fleabay which one would you recommend? I need it to be able to measure at least up to 5000 uF and having some sort of charge protection would be a big bonus (not sure if any of those 5-10$ units have any protection).
Adrian_ is offline   Reply With Quote
Old 11-29-2017, 12:11 PM   #865
stj
stj's Avatar
the AY-AT type colour kit is probably the best.
it's got the most features, and being a kit you can fit a better voltage reference and faster crystal without desoldering the old ones.
i'll just add that if you dont own an atmel programmer then spend 2$ on a USBasp as well - so you can keep the fiirmware up to date.
Old 11-30-2017, 01:07 AM   #866
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
I just hope that the schematic I used has connections that match that of the ones supported in the code...
Old 11-30-2017, 06:07 AM   #867
stj
stj's Avatar
is the schematic the official one from the pdf?
if it is then be carefull - the pin numbers arent clearly marked if they are for the 28pin dip package or the 32pin smd one.
Old 11-30-2017, 11:58 AM   #868
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
There are a bunch of schematic GIFs floating around, and yeah I am using the 28-pin version. Not sure which one is the "official" one anymore either... though it is on mikrocontroller.net ...
Old 12-01-2017, 12:34 AM   #869
stj
stj's Avatar
https://github.com/svn2github/transi...sh/ttester.pdf
Old 12-01-2017, 02:05 AM   #870
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Ah looks like figure 2.1 is what I'm using, close enough with the 16x2 LCD.
Just need to figure out how I want to attach the LCD, and which LCD from the pile I want to use (have both 2x7 and 1x14 pin orientation types of LCDs...)
Old 12-01-2017, 04:40 AM   #871
stj
stj's Avatar
i hate those displays and binned a lot recently.
choose the one with a backlight and the best contrast.
Old 12-01-2017, 01:56 PM   #872
hal9008
City & State: Sao Paulo
My Country: Brazil
Thanks stj for posting the "AY-AT", I install today and the font is bold and very small. different from your old version (SVN700).
hal9008 is offline   Reply With Quote
Old 12-01-2017, 02:01 PM   #873
turbochris
City & State: Grovetown GA
My Country: USA
OK here it is with my li-po mod and ISP header mod. The lipo is 1500mah and has protection circuitry built in. The second picture is how i wired the charger and boost converter in to the tester, I found this diagram online at this site- https://www.thingiverse.com/thing:1797074 My charger/boost converter was one piece so I cut a trace and separated the 2 the same way as this person did about 1/2 way down in this thread- https://www.jyetech.com/forum/viewtopic.php?f=19&t=1153
I also changed the resistor on the boost converter part to 100k and it output 6.5 volts.
Now it's time to try out the firmware that stj cooked up for me! Is there a guide anywhere that shows how to use the makefile and compile custom code?
turbochris is offline   Reply With Quote
Old 12-01-2017, 10:30 PM   #874
stj
stj's Avatar
throw the makefile into a text editor - it's full of notes
what's the output voltage of the boost convertor?
just asking because your passing it through a 5v regulator that probably needs atleast 6v to function.
Old 12-01-2017, 10:58 PM   #875
turbochris
My Country: USA
it was originally a 9 volt converter, i changed a resistor and made it 6.5 volts
Old 12-02-2017, 03:00 AM   #876
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
I also really wonder about those HD44780 displays run write-only... I ended up writing some AVR code that does proper read/write loop and the update speed is quite snappy, was using this on my PSU project and it's fast enough to be about illegible while holding down a button for auto-repeat (press down=move by 1 (debounced in software), hold down 0.5 second = auto repeat by 1, fast.) I initially did it write-only to save a GPIO pin, simply couldn't get it to update fast...
As it was a PSU, it also had a voltmeter and ammeter. Both were updating in excess of 20fps, which is probably faster than one really can keep an eye on anyway and still be able to read it...
Old 12-02-2017, 07:46 AM   #877
stj
stj's Avatar
i had the hitachi dev manual once,
you only use read to check the ready flag after a write.
most people just use a delay equal to worst-case between writes and ignore the ready signal.
Old 12-02-2017, 12:22 PM   #878
turbochris
My Country: USA
I opened the makefile with a text editor. Actually I opened all the files with a text editor. When i was a child i was always taking things apart to see what was inside. I cann see how i can chane all kinds of configurations in the makefile, getting the makefile to generate the TransistorTester.eep and TransistorTester.hex files is where i'm lost. do i use something like winavr?
Old 12-03-2017, 03:11 AM   #879
stj
stj's Avatar
yes,
but you need to overwrite gcc with an older version - unless they fixed that now.
Old 12-03-2017, 01:00 PM   #880
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
What version of gcc and other toolchain is recommended?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
