I'm facing the same problem with an LE37B530 at the PCB BN44-00301A.
Problem: when it turns on the welcome sound is heard, but no backlight nor a picture. Intermittently the TV turns on and runs normally for hours.
I suspect the switchmode power supply at the hot side. As I measure the voltage across the two caps 82uF/450V only at 315V.
+5V, and +13V are present as well as the SB voltage.
I read a lot of posts in here, but I could not find any conclusion of the problem.
Has anyone a tip what the problem may cause?
Or a circuit diagram would be most helpful.
Thanks in advance
Olaf
The PFC Voltage booster circuit is not working, we need good clear pictures of the bottom side of the board to locate the PFC Controller IC to check to see if it has VCC to run IC.
the device is ICP 801 and it read EK17 FAN7530.
Is there any circuit diagram of the PCB available?
Cheers
Olaf
OK, I forget to ask you to check PFC Diode DP801 to make sure it does not conduct in both direction or not, if it is tested OK then check the DCV for the PFC IC.
I do not have the diagram. Look up the spec sheet of the FAN7530, then check the DCV between VCC and the GND pin when TV is turned on to see if it its getting any DCV to run.
You will be working in the primary deadly side of the circuit so do not touch anything with your hands or body, you should plug the unit into the GFCI outlet for protection.
thanks, I got the data sheet and I measured the VCC OK with 13VDC between pin 6 (GND) and 8 (VCC). I suspect the reference at the internal zener diode (pin 5) not alike 6.5V but 0.7V.
The diode measures OK.
Any idea to that? Right now that bastard shows a nice picture.
I think to replace the FAN 7530.
Does anyone have reliable source to buy?
Cheers
Olaf
Are you sure you are not getting around 400VDC measured between the two legs of the main filter cap? The Inverter circuit needs that boosted Voltage to function, at 315VDC as you reported the protection circuit will kick in and not allow the backlights inverter circuit to come on.
