Its a Dell...Dude
Its a DEAD Dell power supply with a blinking green LED on the back of the case. She is a Dell 265 watt, DP/N 0053N4, OEM is LightOn. Pushing the small "reset" switch next to the green LED on the back of the case did not help any.
Time for surgery. The LED on the back indicates status of the 5VSB circuit. The "reset" switch next to the LED is not a reset switch, but acts like a PS_on switch, or like shorting the green wire to ground to turn on the power supply. The blinking LED on the back of the power supply indicated that the 5VSB was pulsing.
The 5VSB circuit uses an Infineon ICE 3AR2280JZ-1 chip. I traced the circuit to determine what was there. See attached drawing. Then began preliminary checks for shorts using digital voltmeter. I quickly found that diode D600 coming off the feedback winding of the 5VSB transformer was shorted. This diode is a UG1D 200 volt 1 amp switching diode. Since I didn't have one handy, I substituted a 1N4935 switching diode with similar specs. Applied power and now she works just fine.
So here are some pictures of the power supply. And remember, it's a Dell...Dude
