NCC KY 6.3V 470uF
    NCC KY 6.3V 470uF
    Are all NCC KY 6.3V 470uF fake? I can't find them in the datasheet..
    Re: NCC KY 6.3V 470uF
    You have any pictures of them?
      I located them on ebay.. Based on the data sheet they appear to be 330uF based on dimensions.. These are from egecku / pcmcs..
      http://www.ebay.ca/itm/290723626322?...84.m1497.l2649
        Although it's certainly possible that they are fake, this guy is well known for selling non counterfeit caps. More likely it's just a specialty size made for an OEM that didn't use them all.
        It's actually pretty common. I have a nice stash of UCC KY 3300uf 6.3v in 10x30mm, that don't exist according to UCCs data sheet. They are quite genuine, identical in every way to the UCC KY 2200uf 10v
        caps I got from Digikey, right down to the luster of the aluminum cans.
          The 3300uF 16V samxon RS caps don't appear in the datasheet, but they weren't fake. They were just a custom size
            The 10mm RS?
            I figured this was the possibility.. Just odd I guess since the dimensions match 330uF.. I've never had badfakecaps from this seller so was curious..
              If you commit to the volume and pay the price (usually not horrible) "big boys" like Nichicon and UCC will do custom parts.
              PeteS in CA
                Ok.. Thanks,
                  As others have said, probably not fake. I spot three of them in my Netgear
                  DG834G wireless router. Unless the factory uses fake caps.
