Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices
Old 08-15-2018, 04:32 PM   #1
Blacktek
Blacktek's Avatar
City & State: Houston
My Country: United States
Default Toshiba P305D shorted out when using tweezer to power on. what to check first
i need help, i have this laptop that i was troubleshooting because it had no image on lcd but working on ext. monitor. i used the tweezer to turn it on about 20 times without a problem, NOW it wont turn on, only the cd tray start/makes noises, but no light, no fan spin, DEAD.
What should i check first?
Blacktek is offline   Reply With Quote
Old 08-15-2018, 05:01 PM   #2
fester
City & State: Kopcany
My Country: Slovakia
Line Voltage: 230V 50Hz
Default Re: Toshiba P305D shorted out when using tweezer to power on. what to check first
first,all run voltages must be present. simple - meassure voltage on every bigger coil after switching it on and compare with schematic.
fester is offline   Reply With Quote
Old 08-15-2018, 05:32 PM   #3
Blacktek
Blacktek's Avatar
I have my 3.3v, 5.1v present
what other voltages should i check for?
Old 08-15-2018, 10:51 PM   #4
mcplslg123
City & State: siliguri
My Country: india
Line Voltage: 220vac,60hz
check +15v ALW, 3V_5V POK, PCH RSMRST,KBC PWRBTN_EC# and if you all these present then check for PM_SLP s4# and PM_SLP S3# Signals. Unless and otherwise you have pm slp s3 and s4 signals you wont have rest of the signals.
mcplslg123 is offline   Reply With Quote
Old 08-21-2018, 11:09 AM   #5
Blacktek
Blacktek's Avatar
THanks for the input, I have 3v and 5v coming out of those coils, Instead of 15V i have 7.20V, the others checkpoint are not on this board or maybe is written differently.
Im attaching the schematic file in case you want to take a look.
Badcaps.net Technical Forums © 2003 - 2022
