Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices
Old 03-09-2018, 12:34 PM   #1
Blacktek
Blacktek's Avatar
City & State: Houston
My Country: United States
Default HP 19 All-in-one, White charger light on, Does not power on.
Hi guys, I have this Computer that is getting power all over the board, even at the power button connection, i did a very good inspection with Microscope but still could find anything out of the ordinary, No water damage.
I even removed the power jack and still nothing.
Any suggestions?
Blacktek is offline   Reply With Quote
Old 03-09-2018, 01:21 PM   #2
tibd
City & State: ostergotland
My Country: Sweden
Default Re: HP 19 All-in-one, White charger light on, Does not power on.
reflash bios.
tibd is offline   Reply With Quote
Old 03-09-2018, 05:58 PM   #3
Blacktek
Blacktek's Avatar
wow, its weird how bios can cause this.. Can it be flashed using usb? or do i have to find a dump and program it?
Old 03-09-2018, 10:44 PM   #4
mcplslg123
City & State: siliguri
My Country: india
Line Voltage: 220vac,60hz
You need to find a dump and program it with a spi programmer. Check hp site for bios.
mcplslg123 is offline   Reply With Quote
Old 03-10-2018, 10:34 AM   #5
Blacktek
Blacktek's Avatar
Ok thanks, only things is HP website all has .exe files, how do i get a .bin from that?
Old 03-11-2018, 12:33 AM   #6
mcplslg123
My Country: india
Post your old bios here with complete pc model number and mb markings if any. I'll try to help you.
Old 03-12-2018, 11:49 AM   #7
Blacktek
Blacktek's Avatar
Here you go. Markings on chip:
Winbond
25Q32FVSIG 1412
Board markings:
AMPKB-PT
Rev:1.02
Old 03-12-2018, 12:06 PM   #8
Blacktek
Blacktek's Avatar
Check it out, above this post.
Old 03-12-2018, 02:30 PM   #9
Blacktek
Blacktek's Avatar
Could this possibly be the SIO it8528e?? How do i check this chip to see if its working correctly?
Old 03-13-2018, 07:01 AM   #10
mcplslg123
My Country: india
Your bios backup is almost blank. So either your bios is definitely corrupt or the backup was not proper.
Since i could'nt verify your backup bios , still i'm attaching hp official bios you can try.
There are 3 types of bios in this series-so might not match-but still you can try.
Goodluck
Old 03-13-2018, 09:22 AM   #11
Blacktek
Blacktek's Avatar
Goodluck
Thanks buddy, i will try this bios now, first ill see if i can retrieve more using a different eeprom.
Old 03-13-2018, 09:44 AM   #12
Blacktek
Blacktek's Avatar
How about this one? i Used a different Programmer.
Old 03-13-2018, 10:31 PM   #13
mcplslg123
My Country: india
backup this time seems ok. Your bios is dai 8004 and i have uploaded dai 8006 which is newer. It should work as long as it is bios issue. If you face win licence and serial number missing then that can be fixed later. But first check whether you get display.
Old 03-14-2018, 09:24 AM   #14
Blacktek
Blacktek's Avatar
no powe no display, charge/power light from the power brick is ON but when i press the power button nothing happens.
Old 03-14-2018, 11:19 PM   #15
mcplslg123
My Country: india
So not a bios issue. Schematic available for your mb?? If not then pickup another schematic with same SIO and try to check voltages at sio pins. You may get some clue.
Old 03-15-2018, 11:18 AM   #16
Blacktek
Blacktek's Avatar
Good idea, i have over 20 laptop boards and none have this SIO, ill check the web.
Old 05-21-2018, 03:47 PM   #17
Blacktek
Blacktek's Avatar
It Happened again on a replacement board!! Ordered new board, installed it and it worked for a few days, Its been a couple of days since i dont turn it on, now i tried to use it but its DEAD AGAIN, SAME SYMPTOMS.
Power all around the board, even the power button. but nothing happens when pressed. this is a replacement board from ebay. it worked for a few days now its dead.
RTC/Coin Cell battery was 2.7v, replaced it but still the same.
PLEASE HELP!
Old 05-25-2018, 12:19 PM   #18
Blacktek
Blacktek's Avatar
No one?
Old 05-25-2018, 01:27 PM   #19
SMDFlea
City & State: York
My Country: UK
Have you tried a different power brick. Is it a standard hp latop charger ,with sense pin.
SMDFlea is offline   Reply With Quote
Old 05-25-2018, 04:45 PM   #20
Blacktek
Blacktek's Avatar
Bingo!! Bad/Wrong Charger
