Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices
Thread Tools Display Modes
Old 08-29-2018, 01:51 PM   #1
Blacktek
Blacktek's Avatar
City & State: Houston
My Country: United States
I'm a: Knowledge Seeker
Default HP DV6 Backlight works but no video, ext. monitor shows video.5v resistor burned.
This laptop had a resistor on a 5v rail, replaced it with another resistor different value..still only shows backlight.
im including schematics....Burned resistor was on a 5v rail on CN2(LCD Connector).
What else should i be looking at?
There is 5v on both sides of new resistor.
Blacktek is offline   Reply With Quote
Old 08-30-2018, 10:53 AM   #2
Blacktek
Blacktek's Avatar
Default Re: HP DV6 Backlight works but no video, ext. monitor shows video.5v resistor burned.
Please guys.. any input will be appreciated..
Old 09-25-2018, 02:59 PM   #3
Blacktek
Blacktek's Avatar
Bump...Anyone?
Old 09-25-2018, 03:37 PM   #4
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Do you mean R2 ??? It is 75Ω, why would you replace it with a different value? and what value did you use?
If you measure 5 volts on both sides, that tells me there is no current drawn through it so no voltage drop, so check where it goes in the panel, thats likely where your fault is.
R_J is online now   Reply With Quote
Old 09-26-2018, 10:02 AM   #5
Blacktek
Blacktek's Avatar
THANKS for the input! i replaced it with a 100ohm resistor, but there is 5v on both sides of the resistor, when you say to check where it goes, did you mean the lcd connector side of if or the side where its bringing the voltage.??
Old 09-26-2018, 10:53 AM   #6
Blacktek
Blacktek's Avatar
I've replaced both the resistor R2 and the cap C4 with the right values and still only shows backlight no image, Same voltage on both sides of R2...Could it be the LCD cable?
Old 09-26-2018, 11:43 AM   #7
ktmmotocross
Boardkiller
ktmmotocross's Avatar
City & State: slovakia
My Country: slovakia
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
u think that burned resistor is main reason for no video?
ktmmotocross is offline   Reply With Quote
Old 09-26-2018, 12:23 PM   #8
Blacktek
Blacktek's Avatar
Thanks guys for all your support...I FOUND THE CAUSE OF THE PROBLEM..i was just being lazy by not removing the LCD Assembly take a look at what the resistor did...
Old 09-26-2018, 05:02 PM   #9
R_J
City & State: ☻
My Country: Canada
The resistor did NOTdo that, The ic shorted and blew the resistor, the resistor acts like a fuse in this case.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
