Re: Bad caps or inductors on Klipsch ipod speaker unit
Ok, so what i did may not be 100% valid but i think it may prove my point. Recall that i removed two caps.........one was worse than the other. The worse one was in the same position as CapA. The other had a measured cap value of ~ 420uF (should be 470uF). I put the 420uF back onto the board in place of capA. The goal here is that the original ones should have ripple and ESR values that are good.........provided the caps are good. I think the 420uF cap is good enough for this test.......but there is a possibility that its not.
I put the 420uF original cap back in............still got hot. As best i can tell at the same rate as the other one.
So i dont think the actual cap is the problem. I think its something else.
Willing to take comments on this.
Also, willing to take suggestions on what to try next.........not sure what to measure. I have measured the voltage across caps when power is turned on......its 15V..........once song starts playing voltage drops to 8V and starts to heat up slowly. Almost not noticible at first.
Could the power cord be somehow causing the problem? I dont know. Suggeestion would be great. Otherwise to the trash this thing goes.
