Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Old 08-28-2020, 10:08 AM   #121
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
Default Re: Original Xbox Replacement Caps
( One note no where in the majority of seller sites do they mention that they are nock offs ) you have to know this information
My I phone is giving a headache not wanting to corporate today
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 08-28-2020, 11:11 AM   #122
stj
stj's Avatar
City & State: Europe
Originally Posted by jayjr1105 View Post
My power supply is a foxlink, should I replace the 4-5 teapo's in it? I think they are mostly 2200uf 10v
if it's like the european foxlink supplies then check the 1200uf caps.
they always seem to be trashed.
Old 09-05-2020, 08:56 AM   #123
jayjr1105
jayjr1105's Avatar
City & State: Central PA
My Country: United States
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
I took inventory of the caps on it and ordered everything, minus the Mains filter cap everything is getting replaced. My Ali poly's are taking forever to come in so the PSU is getting electrolytic's
Ryzen 3600x
16GB Patriot 3600MHz
MSI B450 Gaming Plus
MSI Air Boost Vega 56
Acer 32" 1440P Freesync
Rosewill Capstone 750W
Hakko FX-888D Station
FX-8802 Iron
MG Chem .8mm 63/37 RA 2.2%
jayjr1105 is offline   Reply With Quote
Old 09-07-2020, 07:54 PM   #124
jayjr1105
jayjr1105's Avatar
Foxlink recap all done
Last edited by Per Hansson; 09-13-2020 at 01:10 PM.. Reason: Offsite image uploaded
Old 09-11-2020, 11:02 AM   #125
jayjr1105
jayjr1105's Avatar
I got all my Ali caps in today. A little disappointed in the 1500uf 6.3 poly's. Using an LCR meter they all tested rather low but not out of spec. 2 of the 20 did test out of spec at 1000uf. The rest were 1300-1400uf. Not a single one at or above 1500uf. I find that odd.
Anyway, here are the 3300uf Sanyo WG's. Probably fake, you tell me.
https://imgur.com/gallery/y1vqqhO
I did remove the label from one of the Sanyo's to find a vertical scratch, usually indicating a fake but it tested right at 3300uf with 0.01 ESR
Last edited by Per Hansson; 09-13-2020 at 01:10 PM.. Reason: Offsite images uploaded
Old 09-12-2020, 12:26 PM   #126
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
I can't see those IMGUR external pictures. Can you please attach images using the forum's built-in feature? Online image hosting websites go up and down all the time, and I've seen it far too many times where after a while, a thread that is meant to have pictures has none.
Old 09-12-2020, 01:08 PM   #127
stj
stj's Avatar
the images dont show the bung
Old 09-12-2020, 07:03 PM   #128
jayjr1105
jayjr1105's Avatar
Here you go
Last edited by Per Hansson; 09-13-2020 at 01:11 PM.. Reason: Offsite image uploaded
Old 09-12-2020, 07:15 PM   #129
jayjr1105
jayjr1105's Avatar
Bonus pic, cut the naked one open with a razor blade. Wound very tight with many many layers. Had good moisture. If it's a fake it's not a bad one.
Old 09-13-2020, 08:23 AM   #130
jayjr1105
jayjr1105's Avatar
Nevermind about them being real. They are 100% fake. Further ESR testing shows them between .03 and 0.6 ESR (tested all of them) and the datasheet specifies .012 max at 100KHz 20c
Similar caps new and old test accurately around .02 to .01
Last edited by Per Hansson; 09-13-2020 at 01:12 PM.. Reason: Offsite images uploaded
Old 09-13-2020, 01:13 PM   #131
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Yea 100% fake, Sanyo / Suncon do not use bungs with concentric rings.
And only some larger caps have the X vent, 10mm caps have K type vents.
Old 09-15-2020, 10:58 AM   #132
jayjr1105
jayjr1105's Avatar
What's the story on these green KZE's? XBOX is a 1.0 and a very early if not first batch.
They look okay but wasn't sure if these were capacitor plague era or not.
Last edited by Per Hansson; 09-19-2020 at 12:50 PM.. Reason: Offsite image uploaded
Old 09-15-2020, 11:44 AM   #133
momaka
master hoarder
momaka's Avatar
My Country: U.S.A.
KZE -> very very reliable
I would leave them.
I still don't see half of the images from the offsite links, but the one that did load up eventually... yep 100% fake indeed.
jayjr1105, can you please attach images with the forum's built in attachment tool? (click "Post Reply" or "Go Advanced", then click on the "Manage Attachments" below the message prompt.) Someone's going to view this thread a few years from now, and I bet you most of the off-site images will be gone.
Old 09-16-2020, 07:39 AM   #134
jayjr1105
jayjr1105's Avatar
I would leave them.
Thanks, I did pull one of the KZE's yesterday and it tested out great, very low ESR and well within spec for capacitance.
I did post some images last week using my screenshot tool (lightshot) and I can confirm it doesn't play nice with hosting images for other websites. I have since started using imgur which should show all my images. Which ones can you not see?
Old 09-17-2020, 11:45 AM   #135
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
What brand officially uses the concentric rings? Seems fairly common as a fake.
BTW I have a bunch of the fake WG Sanyos 2200µF 10V that look just like the 3300µF 6.3V units above, concentric rings and X and all. What really annoys me about fakes is that pretty much all leak at the rated voltage...
eccerr0r is online now   Reply With Quote
Old 09-17-2020, 01:07 PM   #136
jayjr1105
jayjr1105's Avatar
Of the 10 I ordered, some actually had a totally different bung that was more traditionally shaped but still had a X vent instead of K. Also tested well above an very low esr for such a cap.
Stock photo not my actual cap but the bungs on some looked like this https://images-na.ssl-images-amazon....1E3hWoeCmL.jpg
Old 09-19-2020, 12:52 PM   #137
Per Hansson
City & State: ----
My Country: Sweden
Agreed.
But I did attach all pictures last weekend so you can see them all.
Old 09-19-2020, 06:40 PM   #138
momaka
master hoarder
momaka's Avatar
My Country: U.S.A.
The first one with the direct link and I think the one with the Foxlink PSU... and maybe a few others. It was a bit random.
Just to make sure, I did try viewing this thread on different PCs and with different browsers, since I know my Opera 12 can act a bit iffy with newer sites and/or externally linked photos... but that wasn't the case this time. Whatever was going on cleared up after a few days and I was able to view the images before Per uploaded them to the forums.
Teapo... at least I've seen it on a number of small SC series (6.3V, 1000 uF) that came from HP OEM ASUS P4SD motherboards... but not all of them had the concentric rings, so who knows what Teapo did there.
LOL!
Agreed.
Thank you!
I noticed the page also loaded much faster this time.
Old 09-20-2020, 01:24 AM   #139
Per Hansson
City & State: ----
My Country: Sweden
Thank you!
The direct links to imgur are still there for the inline pictures.
I always do it like that: just attach the linked picture without changing the link itself.
(As long as it points to a https source and actually exists that is).
Old 09-21-2020, 10:52 AM   #140
jayjr1105
jayjr1105's Avatar
Any harm in using fewer caps around the CPU? The XBOX either has five 1500uf caps or three 3300uf caps. Could you simply populate two 4700uf caps on the left and right most sides? You can get away with about 27mm (maybe 30) height and 12.5mm width. Just curious if it quantity matters vs sticking with same bulk capacitance and voltage.
Badcaps.net Technical Forums © 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
