Hi, Guys, I removed pu401 .3.3 volts power ic SY8208BQNC as it was getting hot and had no 3.3 volts on the motherboard but before i replace it on pin 5 vcc on the motherboard im getting continuity to ground is this normal i just want to double check before i put on the new power ic on .Thanks In advance
Lenovo 80nj 3.3v Alw power ic Replacment
Re: Lenovo 80nj 3.3v Alw power ic Replacment
Thanks Techtiger for your help. i'm a bit confused according to the pin out on the datasheet which i have attached its says vcc on pin 5 second pin down.I will check what u have suggested and see if i can find the short. ThanksYour never to old to learn
Originally posted by garrymc123 View PostThanks Techtiger for your help. i'm a bit confused according to the pin out on the datasheet which i have attached its says vcc on pin 5 second pin down.I will check what u have suggested and see if i can find the short. Thanks
I've seen this mistake a lot recently but indeed this is very confusing.
Pin assignment of SY8208 is not the same on the A, B, C and D variants. Datasheet shows only A variant. Note that several Compal schematics have the wrong footprint for SY8208 (as it is the case here on Compal LA-B092P I think). Compal LA-9535P has the correct footprint for SY8208B and SY8208C. Also boardview for Compal LA-9535P is available if you want to make sure which pin is which on the chip.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Originally posted by piernov View PostI've seen this mistake a lot recently but indeed this is very confusing.
More info:
Originally posted by fzabkar View PostThe SY8208 part was manufactured by Silergy (it was also the subject of a patent infringement case). AFAICT it has at least three versions -- adjustable (DQNC), 3V fixed (BQNC), 5V fixed (CQNC).
Note that the suffix is VERY IMPORTANT.
he SY8208DQNC incorporates an adjustable step-down switchmode converter with a feedback reference voltage of 0.6V.
The SY8208BQNC appears to be a fixed 3V converter, and the SY8208CQNC appears to be a fixed 5V converter.
Just realised its the wrong schematic for my board bit it is similar tho mine is _la-b092p_r1.0_ anyway i couldn't find anything shorted so i injected 3.3 v on that line that was short to ground and it was the big chip that heated up is this my problem chip?Your never to old to learn
Originally posted by garrymc123 View PostJust realised its the wrong schematic for my board bit it is similar tho mine is _la-b092p_r1.0_ anyway i couldn't find anything shorted so i injected 3.3 v on that line that was short to ground and it was the big chip that heated up is this my problem chip?
Originally posted by garrymc123 View PostHi, Guys, I removed pu401 .3.3 volts power ic SY8208BQNC as it was getting hot and had no 3.3 volts on the motherboard but before i replace it on pin 5 vcc on the motherboard im getting continuity to ground is this normal i just want to double check before i put on the new power ic on .Thanks In advance
good afternoon,
I really have defect what do I
help me please ??
