Found this forum just a week back and it`s awesome, lots of useful stuff here and the community is just outstanding. Thanks for existing!
I got a Gigabyte GA-7VT600 MB, salvaged from recycle bin, because I thought it was faulty.
One day I decided to test it once again and to my surprise it worked well at first glance. I`ve installed an OS, drivers and even some games. But then for unknown reason I removed it from the case to discover that it has about 4 caps(EC31,EC33,EC36,EC38) missing (didn`t noticed this when putting it in). I must admit that I didn`t stress test it, but it seems to work just fine.
So here are my questions to you guys:
1. How is it possible to work fine under those circumstances? You can see that those caps missing are around CPU.
2. What caps are needed since I believe that it won`t last long before it dies without those caps?
3. The only problem I encountered when installing drivers was that there was no sound was coming from speaker out hole (green one) but oddly enough the driver "sense" when a jack is plugged in. If set to emulated 5.1 speakers, there is still no sound on the green hole, but the blue one (line out) which acts as the back speakers has. Could the missing caps cause this problem too ?
On another note, I suspect that there are another two caps missing(see pic #2, rectangle shape) but I can`t be sure since there is no resin left like the other 4.
Any feedback will be appreciated, guys! Thanks!
