I need help on this hp 14-am096tu laptop cannot boot because it has an error of system fan error 90b, i check the fan and removed in the board and check with bench lab by injecting on + and - 3v the fan is spinning. anyone help on this
hp 14-am096tu system fan error 90b
Re: hp 14-am096tu system fan error 90b
Originally posted by Romy2018 View Posti will try to flash the bios does someone have a good working bios for this please help
Backup your bios first, find your BID number ,flash the bios.
thanks smdflea. I tried flashing the bios still the same issue system fan error 90b and cannot detected hard drive.anyone who encounter this problem please help
I have uploaded original dumpAttached FilesLast edited by Romy2018; 12-21-2018, 08:44 PM.
I still not solved this problem but i found a clue on this two caps near fan connector there is no 5v and on the other side the one cap near the hdd connector has no 5v also and then this cap is connected to the two caps near the fan connector.but when i reheat the two caps it works and after shutdown and leave the laptop for a couple of hours and tried again i came back to the same issue.anyone could help me on this please!!! i have upload the image
u have to find 5V switch. maybe it is that ic . u must check its datasheet
reheat caps???Last edited by ktmmotocross; 01-04-2019, 12:21 PM.
