Help with DE-5000 results
    I am trying to use the DE-5000 to test some caps. I am new to this and would appreciate some input.
    Junzl 100uF 400V
    In Cs Mode:
    100hz Cap 88.17 ESR .9
    120hz Cap 87.95 ESR .8
    1khz Cap 85.6 ESR .57
    10khz Cap 77.1 ESR .52
    100khz Nothing "OL"
    Rs
    100hz .90
    120hz .83
    1khz .57
    10khz .51
    100khz.49
    What results should I be looking at and why?
    The datasheet seems to spec 100khz?
    ESR meters like the Atlas ESR70 or the Blue appear to simply auto adjust frequency and simply display values. What are they doing?
    Thank you.
    Re: Help with DE-5000 results
    ESR70, blue and a few other are fixed frequency afaik.
      The cheap meters don't do a proper test, but it's a close enough approximation to give a decent result over a wide range.
      A high end meter like yours has the ability as you found to test at the frequency listed in the datasheet.
      It's simply a more reliable method vs "winging it"
        Given this data sheet. What is the appropriate test frequency for 1. Capacitance, 2. ESR
        https://cdn.badcaps-static.com/pdfs/...0df5a37c01.pdf
        Rule of thumb appears to be 120Hz for over 10uF and 1kHz for under 10uF. ?
          The rule of thumb is that General Purpose caps are 120Hz.
          And low impedance (ESR) caps are rated for 100Khz.
          But it should always be listed in the datasheet.
