Used ITE chip replacement
    i have this asus board with dead IT8995e chip and i have to replace it...Before, i always ordered and used new chips but this time i have one other motherboard with dead gpu so i was thinking to use it8995e from that board....
    I understand that when using a new IT8995e chip on asus board it will reprogram automatically with first power on...but what about used chip?
    Basically, the question is can i use working old ITE chip for replacement on other asus board?
    Thank you!
    Re: Used ITE chip replacement
    If you have got no ITE programmer, do not do that. Instead, you may be able to convert the failed-GPU mainboard to UMA.
      yes i have ITE programmer but it is much more easier to just install new ITE chip on asus laptop boards.
      The main problem is that sellers on ebay states it is new ite chip... but when it arrives in couple of weeks it is often used (with solder on the pads for example, obviously removed from some motherboard) so i have to order a new one ... and lost couple of weeks more.
        more easier? it is just a few wires
