Re: Big Heatsinks
Here's a few more things to consider in order to drop temps a bit. Lap the mating surfaces of the cpu and the heatsink. They're not very flat (in most cases) from the factory and can net you at least a few deg C in temperature drop. It's also very important to use a minimum of thermal compound when both surfaces are flat and smooth. I go from 400 to 1500 grit wet or dry automotive sandpaper lapping wet with a bit of detergent. It really helps a lot. Also, moving cables and wiring out of the way really helps airflow and decreases turbulence.
On the aside, there's 2 silly designs in most modern tower cases that should be rectified. 1st, the power supply should be mounted at the bottom of the case so it doesn't have to suck in hot air as well as generating it's own. 2nd, video cards are mounted upside down IMHO. All that heat from the GPU gets spread out along the bottom of the card heating it up unnessesarily. There's not to much that can be done about those issues though.
