need help fixing a macintosh G3 AIO power supply
    I have a power supply for a power macintosh G3 AIO that chirps when i try to power it on. I've located the coil that the sound is coming from. the numbers on it are:
    6170TMZ027A
    NY9815
    everything on the board looks fine... no swollen caps or anything as far as i can tell
    any ideas how to fix it?
    Re: need help fixing a macintosh G3 AIO power supply
    check the output diodes,
    chirping is often caused by the output being overloaded
      6170TMZ027A
      NY9815
      Did you get your G3 power supply working? I have the same issues.
