hp 15-an050nr bios
    hp 15-an050nr bios
    Could really use help getting this dump DAX1BDMB6F0 REV:F
    Re: hp 15-an050nr bios
    I have been able to extract the file from hp original execution file with all the different BID numbers. Could be of use to someone. all are 100% working.
      how to remove manufacture mode is in unlock mode ?
      080a0 tested ok but got that stupid message :/
      thx
        thx
        Try this
          thx !!! finally mystery solved
            Here is a DAOAX2MB6F0 dump which I have set a new Intel ME section. Flash and go. BIOS is in chinese. Just change the language in the BIOS settings. I could not find a recent enough version of the DMI tool to set the serial. This BIOS has a serial number on it.
              duvelhedz it works your dump thanks
                file good thanks!
                  it works fine thanks
                    How to identify the correct version without an original dump ?
                      EDIT: wrong info.
                        Help to identify correct bios
                        Hp star war edition DAX1BDMB6F0 REV:F
                        080A0 fan spin but cpu cold
                        080A9 fan reapeatly stop and go but cpu cold
                        0809B fan not spin cpu cold
                        08092 fan spin but cpu cold
                          You can try all bios you know which is original if work your laptop.Different bid is not work i experience same hp laptop same not know what bid is original board i try all 1 by 1 then 1 bid work for me.
                            EDIT: 80A0 is the correct Bios i5-xxxxU ,i7-xxxxU Skylake U
                                intel i7-6500u SR2EZ
                                I would like to be sure of the bios before starting a search for a hardware problem
                                  Yes, 080A0 is the right one.Ive added a screenshot of the platform.ini file from the bios update.
                                  The schematic is posted on another thread: https://www.badcaps.net/forum/showthread.php?t=73893
                                      You`re welcome .
                                        Thank you brothers
