Re: low or super low ESR + impedance caps
willawake - you win. I can't produce them, so it might be just as SoddemFX say - the DFI design produce too much spikes and stuff, witch - together with my fanless madness, killed the Chemi-cons easily. Now I use Panasonic FM ones and we see about them. Also read bellow - I thinking about add ceramics to filter the crap out... Witch in fact also kill then the possibility so we don't know for absolutely sure that the DFI LP B/Ultra Infinity mobos are cap-killers...
davmax - guys, I don't (also can't because I lack so many english terminology words I desperately need) want to fight. No way. I have better things to do. But please, please please next time try to read what I write, thanks!
I mean this:
If you actually bother to read what I trying to say (excuse typos and stuff, pls), I was trying to tell you THIS:
I don't know - it is really so hard to understand that when the wires used to measure with my multimeter has 0.1 ohm, then the coil has to have less that measurable resistance? Do I really need explain this to you? You never measured something that is close to your measuring equipment resolution so you know, that you have to measure also the wires you using to connect the coil to the multimeter? And the fact, that if they show the excactly same resistance, then the coil was far less, probably less that 0.01 ohms resistance?
Again - the thick cooper wire, witch has not measurable resistance - okay now?
And now - I reporting sucess!
Imagine this - yesterday I removed the heatsinks from the AGP/PCI voltage regulators - it is Arctic Silver epoxyde, however when you heat it up with big 250W soldering iron to 160°C, it get off easily. But WTF? Machine become really stable after this "modification", so I get a little theory what happen and why.
IMHO when the caps fail, the regulator(regulators) started to overheat like mad. They will for sure get burned-out, luckily the heatsing on them and it's weight pulled them out a little, when the tin get melted and therefore the mosfet lost's it's contact. That was the few sec after the explosion and before the hangup witch started all this...
Now, when I heating them up, I made them solder a little better their backs to the mobo, so that is why the mobo started to like PCI devices... So, I soldered them real good, reseted bios (long time, it was quirky again) and then even with the added capacitor 470uF at the position 10 it booter right to WinXP with FX5600 and Audigy inserted, where before it produced only 4LOD
I was wanted to test 6800LE as well (replacement card), however due to the big SB cooler and the 6800LE equiped with a Silencer it won't fit. So the final test will be done into the box, seems
Happy!
I probably better wait for the SMD ceramic caps to make the filtering better and also add the caps from back to support higher FSB where Last Viking suggested
(yes, replace the two 1000uF 10V ST RLG 352 caps with Panasonic FM ones and add two 2200uF 10V Panasonic FM ones at the bottom of the mobo - hell, another hole to the metal backplate on witch the mobo get screwed up is need, LOL - like my machine don't have enough holes already!)
I mean this:
1: ESR. You measured 0.1 ohm.
...not try to tell me that the toroids on my mobo heating-up because of resistance of the thick cooper wire, witch (as I measured recently) has not measurable resistance (that it is - the quality multimeter of mine measuring 0.1 ohm for it, but the very same 0.1 ohm it says for the measuring wires only, so...) then we should get along fine
Happy!
