uTECH -40 c + 85 c caps- is it ok ?
    hello again , thanks for answering my last quastion.
    i looked for caps : 2700 uf 6.3 v 105 c
    i found 3300 uF 16v that are labeled -40 c + 85 c
    the maker is uTECH
    can i use this caps :?:
    tahns
    I would not recommend using 85* caps in place of 105* caps. They can overheat and vent easily, especially if the board is in a poorly ventilated case. Substituting 3300uF in place of 2700uF is fine, I've done it MANY times with no probs.
    The 85* caps will work for a while, but if they overheat, say adios to them, they will fail.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
