I realize these ccfl inverters make some heat . But this one you can smell it getting hot and you cannot touch either one of the two transistors underneath (c5706) or the inductor coil on top.
I checked it with an infared
heat gun and it is 250 degrees and climbing . Odd thing is ,it looks like a brand new inverter that someone replaced. I replaced the two aluminum caps just to be sure they were not causing the problem,that didn't help at all.Coul it be that one or both transistors is causing this .
It also looks like brand new light tubes were put in the screen .The voltages going in to the inverter are good ,I can't figure this out without some expert advice ,whaddaya think it could be . I will post a pic here soon of the inverter
