Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > All Others Motherboards
Thread Tools Display Modes
Old 04-04-2015, 05:25 AM   #1
keets
City & State: mumbai
My Country: india
I'm a: Knowledge Seeker
Default Tps51120
Dear sir,
This is my first post on the forum.
I am a using the above part in my design of mother board for colibri V51 module.
The design is based on the colibri_arm_iris _carrier bord v1.1. The schematic is attached.
When apply 24v or 5v at Vin to the circuit. TPS51120 gets warm after some time.
Also I get 3.3 v at VREG3 pin but only 1.34v at VREG5 pin. Also 0.3 volts at VREF2.
Also no output at Pin 26 and 15.
Since I am using this part for the first time , please suggest the test procedure/possible cause for the problem.
Thanks in advance.
keets is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
