Old 09-02-2019, 08:44 PM   #21
Rotorcraft230
City & State: Brazoria county TX
Default Re: Samsung UN65MU6500FXZA won't turn on
Aw man, LOL, you thanks for helping.
and thanks R_J and CapLeaker as well.
Successfully fixed: Sanyo 42" LCD, Sony 52" Bravia XBR9,
Rotorcraft230 is offline   Reply With Quote
Old 09-03-2019, 05:31 AM   #22
Rotorcraft230
Originally Posted by R_J View Post
Ok, then that power supply is working like it should.
Hey R_J, should I be concerned the voltages are higher
2V for standby
1V for on
Mark
File Type: jpg 8BBFC4A5-0AB4-467F-BFF8-BDEAC1E2262F.jpg (213.9 KB, 15 views)
Old 09-03-2019, 05:38 AM   #23
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
I we would be concerned about that, you would know that already.
Old 09-03-2019, 10:07 AM   #24
R_J
City & State: ☻
My Country: Canada
I would not be concerned, It is very likely the board is marked wrong. If you look next to that voltage mark it says A13v:12.8V which is the same point
R_J is offline   Reply With Quote
Old 09-03-2019, 04:27 PM   #25
Rotorcraft230
Thanks for the reassurance. I’ll get a main board and post back.
Thanks Mark
Old 09-09-2019, 08:54 PM   #26
Rotorcraft230
Default Re: Samsung UN65MU6500FXZA won't turn on EDIT FIXED
Just wanted to update the repair on the TV and thanks to
brandontvparts on Ebay
he gave me the best price on the main board and shipping was super fast.
the TV is up and running. Thanks to everyone that helped, you guys are the best and Ill be back on the next one, in the mean time I'll be here reading and learning.
thanks Mark
Old 09-10-2019, 06:53 AM   #27
nomoresonys
City & State: midwest
My Country: U.S.
Glad to hear it, thanks for follow-up report.
nomoresonys is offline   Reply With Quote
Old 04-07-2020, 01:15 PM   #28
brucetv
City & State: springdale ar
My Country: united states
We are seeing a lot of these coming in with a short in the lower driver board. It's tedious to go through the caps removing them one by one to find the short but it's doable. If your Tv backlights and optical on main board are turning on and off unplug the Tv and remove on ribbon cable going to the panel one at a time. If the backlights and optical stays on then the short is on that side you have disconnected. You have to remove the speaker and the lower driver board cover and test those itty bitty caps. Solder tweezers really come in handy for this job. You can also isolate it since each side has two bottom boards by disconnecting the U shaped ribbon. I am seeing most coming in with 3 green and one blue and the short was always on the blue. It's almost like Samsung had a "Houston, we have a problem here" and shoved a piece of crap board in there just to get by. It's marked BN96-39042A Once you unhook that oddball blue driver board the backlights and Tv stays on fine in most cases if it's not the Main board. Check two caps next to CK2 and CK3 on that blue board. We now save the lower driver boards on damaged panel tv's to get the good caps off them for future repairs. I also tell all my customers to avoid this model like the Covid19 virus because this is happening on 2 year old Samsung's and that's not worth the money SAMSUNG! Samsung engineering>
brucetv is offline   Reply With Quote
Old 04-07-2020, 04:21 PM   #29
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
More failed MLCC.
Is that SAMSUNG LCD panel, or other OEM?
Old 04-07-2020, 06:54 PM   #30
brucetv
Yes Bud...more crap from Samsung in their quest to do away without a Tcon board it's taking these caps out prematurely. Samsung panel for sure....here's the panel number. It's a pain in the ass repair and we are so busy we don't even do them anymore for fear another one will go out.
Old 04-07-2020, 07:06 PM   #31
budm
budm's Avatar
LCD panel Made in Mexico? I did not expect that.
Old 04-08-2020, 05:33 PM   #32
brucetv
I remember there was a shortage of MLCC's during that production time so I'm sure they stuck some crap MLCC's in there just to get production out. Also explains why there are 3 green lower tab boards and one blue. Really blows for loyal Samsung fans. Please put the Tcon board back in your Tv's Samsung! Jeez. The whole model sucks with it's cheap snap in plastic bezel that is the ONLY thing holding the panel in. Sucks. The CEO's of Samsung should return their end of the year bonus's for spewing out crap like this out of their Mexican plant.
Old 01-28-2022, 10:41 PM   #33
JaredT
City & State: Star, Idaho
My Country: United States
BruceTV, you have perfectly described the issue I am having with a UN65MU6500FXZA. I plug it in and the backlight and TV come on for a few seconds, then powers off. If I unplug the mainboard, it stays powered on and lit up. I read this post and saw that I do have 1 Blue and 3 Green lower driver boards. I tested with just the blue one disconnected, and it stays on. I also tried with the blue one connected, and the other side U cable removed, and it stays on. This leaves me wondering if I have the same issue or not. The blue board is marked BN96-39042A.
Any help would be greatly appreciated.
JaredT is offline   Reply With Quote
