Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 12-27-2014, 08:49 AM   #1
johnjgjohn
City & State: hamilton
My Country: scotland
I'm a: Knowledge Seeker
Default Lg lcd flickering screen after 15 mins help
Hello all merry xmas
Ive got an lg lcd when i power up everything works as normal for the first 15-20 mi s then the screen starts to flicker or pixelate ive checked for bulged caps and checked ribbon cables but not sure were to go from here ive got a video can it be uploaded here? Then u can see what its doing it gets worse the longer its on
Thanks for any help
johnjgjohn is offline   Reply With Quote
Old 12-27-2014, 11:01 AM   #2
nomoresonys
City & State: midwest
My Country: U.S.
Default Re: Lg lcd flickering screen after 15 mins help
can you post good clear pics. of each of the boards, and one of how they are all connected, what is the model number?, use caution when working with power supply HIGH VOLTAGE on primary side.
nomoresonys is offline   Reply With Quote
Old 12-27-2014, 11:50 AM   #3
Ltank
City & State: Florien, La
My Country: USA
I'm a: Professional Tech
Check P.S. voltages on P.S. accoring to silkscreen legend near connectors. 24vdc to inverters should be stable. check backlight on command , PS-on, standby voltage then tell us what you have. Also check the larger capacitors on the inverter boards that power the backlight bulbs. Use a DVM with negative (black0 lead) on chasis gnd
Ltank is offline   Reply With Quote
Old 12-27-2014, 01:31 PM   #4
johnjgjohn
The model no is 37lc55-za
Old 12-27-2014, 01:34 PM   #5
johnjgjohn
Here is some pics
Old 12-27-2014, 01:36 PM   #6
johnjgjohn
Close up of psu
Old 12-27-2014, 01:42 PM   #7
freakaftr8
freakaftr8's Avatar
City & State: Folsom, CA
My Country: USA
Line Voltage: 120vac 60hz
I'm a: Hobbyist Tech
take the power supply off the TV and check for cold solder joints on the transformer the main inverter transformer the one on the top right
freakaftr8 is offline   Reply With Quote
Old 12-27-2014, 03:33 PM   #8
johnjgjohn
Surely if it was the inverter then i would loose backlight? I tried upload a vid but was taking like 20 mins from my fne then i cancelled it the backlight doesnt flicker or go out its just pixelated like when u have a bad signal on freeview the picture gets lines through it
Old 12-27-2014, 03:35 PM   #9
freakaftr8
freakaftr8's Avatar
My Country: USA
sorry missed that part yes it does sound like a main board problem. is it doing this on all inputs or just one?
Old 12-27-2014, 03:55 PM   #10
johnjgjohn
Quote:
Ive checked all voltages they all seem to be what is stated and are all stable
Old 12-27-2014, 04:00 PM   #11
johnjgjohn
Doing it on all inputs when i first turn it on it works fine for about 20 mins then starts flickering a little but gets worse as time goes so must be heat related
Old 12-27-2014, 05:27 PM   #12
johnjgjohn
Here is a video of what its doing http://youtu.be/hkgiG7O7Jm0
Old 12-28-2014, 07:36 AM   #13
johnjgjohn
Does anyone know what would cause this have a look at the video above thanks
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
