#21 |
Banned
City & State: Mesa Arizona
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
![]() How to by pass LCD screen protection?
Screen Black (no display) failure usually encounter some display only one lamp or circuit protection. For easy troubleshooting , we need to remove (by pass) the protection. OZ9938 remove protection circuit: 1. pin 3 short to ground 2. pin 6 short to ground 3. pin 7 short to ground, remove the grounding resistance ,to remove protection. MP1038EY connecting wire pin 11 and pin 2 ,to remove protection. TL5001 short pin 5 to ground ,to remove protection. TL1451 short pin 15 to ground, to remove protection. TL5451 short pin 15 to ground, to remove protection. BA9741 short pin 15 to ground, to remove protection. BA9743 short pin 15 to ground, to remove protection. MB3775 short pin 15 to ground, to remove protection. AT1741 short pin 15 to ground, to remove protection. AT1380 short pin 2 to ground, to remove protection. KA7500 short pin 1 and pin 16 to ground, to remove protection. TL494 short pin 1 and pin 16 to ground. IF not work, short pin 4 to ground. FA3629 short external capacitor over pin 15 and pin 16 FA3630 short pin 7 and pin 10 to ground, to remove protection. OZ960 OZ962 short pin 2 to ground, to remove protection. OZ965 short pin 4 and pin 6 to ground, to remove protection. OZ9RR short pin 8 and pin 9 to ground, to remove protection. BIT3101 Cavitate pin 2 and pin 15 pins (suck out the solder, let the pins float.) BIT3102 Cavitate pin 5 BIT3105 Cavitate pin 4 BIT3106 Cavitate pin 4 and pin 27 BIT3107 Cavitate pin 4 BIT3193 Cavitate pin 15 pin 3 AAT1100 pin 8 short to ground, to remove protection. AAT1107 pin 15 short to ground, to remove protection. BD9884 short pin17 and pin 18 on the ground capacitance. Can someone use spreadsheet make it better? |
#22 |
Banned
![]() Update:
Caution: Unprotect a circuit is dangerous only for temporally troubleshooting. AAT1100 pin 8 short to ground, to remove protection. AAT1107 pin 15 short to ground, to remove protection. AT1380 short pin 2 to ground, to remove protection. AT1741 short pin 15 to ground, to remove protection. BA9741 short pin 15 to ground, to remove protection. BA9743 short pin 15 to ground, to remove protection. BD9884 short pin17 and pin 18 and ground the capacitance. BIT3101 Cavitate pin 2 and pin 15 pins (suck out the solder, let the pins float.) BIT3102 Cavitate pin 5 BIT3105 Cavitate pin 4 BIT3106 Cavitate pin 4 and pin 27 BIT3107 Cavitate pin 4 BIT3193 Cavitate pin 15 pin 3 FA3629 short external capacitor over pin 15 and pin 16 FA3630 short pin 7 and pin 10 to ground, to remove protection. KA7500 short pin 1 and pin 16 to ground, to remove protection. MB3775 short pin 15 to ground, to remove protection. MP1038EY Connecting wire pin 11 and pin 2 ,to remove protection. OZ960, OZ962, OZ1060 short pin 2 to ground, to remove protection. OZ964 short pin 2 to ground, to remove protection. Tested 3/2015 on Sanyo DP42848 OZ965 short pin 4 and pin 6 to ground, to remove protection. OZ9938 1. pin 3 short to ground. 2. pin 6 short to ground. 3. pin 7 short to ground, remove the grounding resistance ,to remove protection. OZ9RR short pin 8 and pin 9 to ground, to remove protection. TL1451 short pin 15 to ground, to remove protection. TL494 short pin 1 and pin 16 to ground. If not work, short pin 4 to ground. TL5001 short pin 5 to ground ,to remove protection. TL5451 short pin 15 to ground, to remove protection. Last edited by Peter Chiu; 03-29-2015 at 07:01 PM.. |
#23 |
City & State: malta
My Country: malta
Line Voltage: 240v 50hz Malta
![]() Hi
I have been using this forum for quite some time now , and I can say you are an amazing Community . These last few weeks I have been writing a Fault Database for the community Everyone can instantly add new categories and faults entries to share with others You can search the database by category , fault description , or diagnosis / fix . I know I still have some minor bugs I will be working on when I find some free time ![]() Here is the url http://fault-database.host56.com/Faults Register and login. Any suggestions are welcome. |
#24 |
Nyak54
City & State: va
My Country: usa
Line Voltage: 120 VAC 60 Hz
I'm a: Hobbyist Tech
![]() Hiya all.
New to this site and just browsing, for now. ![]() |
#25 |
City & State: Charlotte
My Country: Usa
![]() Have a Samsung ln40A530p1fxza. Showing solarized colors, even the menu letters are messed up. Tried all inputs. Did factory reset in service menu, when tried to calibrate HDMI it always said "Failed". Yesterday tried to watch a football game and as I was browsing games, for a second the picture came back normal but then switched back to solarized colors. Do you guys think it is the T-Con board or a bad cable?
#26 | |
City & State: Windsor ON
My Country: Canada
![]() Quote:
#27 |
City & State: Avcılar-İstanbul
My Country: Türkiye
Line Voltage: 220V/50Hz
![]() Hello there ..
AS15 gamma processor is usually broken. What could be the reason for this? SCL / SDA signal irregularities? Did you study the effect of high frequency? Is the workload? It's a question a lot in my head. If the answers come from your friends, I'll be happy. Please provide a description theorists ... Thank you .. Last edited by Kom; 08-24-2015 at 09:01 AM.. |
#28 |
City & State: San Francisco
![]() Pioneer PDP-42-A3HD
When I turn power ON 1.Green light is ON 2.I hear some relay switching on and off but nothing on display and no control. |
#29 |
City & State: New York
![]() I really need some help, my TV suddenly has no image!
_________________________________ Black Cocktail Dresses |
#30 |
City & State: eire
My Country: ireland
![]() Hi i have a finlux 32"That keeps turning on and off by its self.From what i gather is that i need a firmware update?Heres the model number 32LCDHDS-SAT.Have no idea where to get firmware.Even if someone knows What Vestel cross reference this set is.Any help greatly accepted.
#31 |
City & State: waikato
My Country: new zealand
![]() hey guys have a panasonic 42 inch viera TH-L42U20Z with 7 red blinking lights of doom, can anyone help me with this ?
#32 |
City & State: andhrapradesh
My Country: india
![]() sony led tv klv modal 32R402A fault symtom no standby led not glove 1.2v ok, 1.5v ok, 5.1v ok, and
panel 12v not ok mosfet input 19v ok output not ok thair is no shart circuit. aney one solve prablam please. |
#33 |
City & State: Bakersfield ca.
My Country: usa
![]() This is wrong thread to post your repair questions!
#34 | |
City & State: salt burn by the sea uk
My Country: teesside uk
![]() Quote:
#35 |
City & State: Oakdale, IL
My Country: U.S.
![]() I have a samsung UN60H6203AFXZA with issues to be completely honest I am a novice at best.I have replaced all three boards and the TV will not turn on unless I do not have the LED back lights connected power supply board. The TV does turn on but only when the LED lights are not connected to the power supply board I did a flashlight test that lets me see an image however I don't know how to tell if I need new LED lights or if my power supply board that I ordered was bad. I Am brand new to this site and do not know how to navigate it yet do not wish to break any kind of protocol just do not know where I should start seeking help at?
#36 |
My Country: usa
![]() This is sticky for repair reference
I assume no responsibility for any stupid suggestions I might post. |
#37 |
City & State: WASHINGTON DC
My Country: United States
![]() Hello, I want to know how fix backlight failure in a westinghouse 32' lcd tv DW32H1G1
#38 |
City & State: pristina
My Country: albanija
![]() Needed dump?
COMPATIBLE PRE-PROGRAMMED EEPROM Digitrex CTF3271 U17 Flash W25Q16 or: COMPATIBLE PRE-PROGRAMMED EEPROM EVOTEL ELCD40USBFHD T.SP9100.1D 9252 U17 Flash W25Q16 or: Model No/sn032L153 Chassis MB T.SP9100.1D 9252 Main board MB T.SP9100.1D 9252 LVDS/TCON 320ap0302lv0.1 Panel -samsung lta320ap02 Tuner analog/digital -cdt-sft33840 U17 Flash W25Q16 Last edited by cipy1; 08-30-2017 at 09:31 AM.. |
#39 |
My Country: the U.S.
![]() yes, as above said I'd like to share something. A useful tutorial to solve TV issue.
1. Corrupted MP4 video For the already damaged MP4 video, you can repair corrupted MP4 first and then try to play. 2. Encrypted MP4 video If the MP4 video is encrypted or requires authorization, it can not be played if there is no license or specified program. 3. MP4 video is Stored on USB If the USB does not support high-speed transmission, it will probably not be able to play smoothly or even fail. 4. Higher Bit Rate or Frame Rate As the Samsung TV models are different, it will lead to playback failure if the bit rate or frame rate is higher than the supported standard value. 5. Incompatible Codec The most common Samsung TV MP4 playback problem is because of incompatible codecs. (source from http://www.videoconverterfactory.com/tips/samsung-tv-mp4.html.) |
#40 |
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
![]() Pin out for various capacitors
Willing to help but I'm no expert. |
Thread Tools | |
Display Modes | |
